Prolly have the HU power connected to the car's illumination wire.
dave
1999 Buick Park Ave Ultra
Head Unit: JVC KWHDR720
EQ: Audiocontrol EQL
Front Stage: Hybrid Audio Technologies Imagine 5.25
Sub Stage: In process (will be Boston G310)
Amp: Boston Acoustics GTA-704 4 Ch
Rear Fill: Boston SE953 6X9's
Electrical- 200amp alt- Optima yellow tops front+back- stinger 10 farad cap- cadence 1/0awg+stinger+knu fuses
Head unit- Pioneer 9400bh
EQ- Audiocontrol Four.1
Active x/over- Audiocontrol 6xs
Front stage-B.A pro 50se (in sealed centrapod)
Soundbar- Jbl p652 (NOT for long)
Midbass- Jl cw800 (in sealed intrapod)
Subs- 1 RExxx 12 in cust tuned 33hz box@1ohm (thank u Mobile Enclosures)
Amps- Sub-Orion hcca 2500.1/ Midbass-Alpine pdx 2.150/Components- Alpine pdx 4.150
Thank you all very much, I contacted boss via email and they pointed out 2 RCA outs not labeled for the woofers, and they work fantastic, they also said the power antenna will always work, no matter the channel, so it does work while on all my inputs, I fixed the power issue by re grounding it directly to the floor, all works and everything sounds great. Thank you all once again!
I took a video of it once I sorted it all out, here it is if you wanna check it out.
Bookmarks
