+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Question about distribution blocks...
  1. #16
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,078
    2 Post(s)
    Re: Question about distribution blocks...
    Quote Originally Posted by Mills561 View Post
    After doing a little research I found you should NEVER tap into the fuse box for the power wire. I'm pissed the guy didn't let me know he did this. I'm running only ~100 watts to the high amp but should I go ahead and switch it to the battery?
    Run your 4ga power from the battery to a fuse box, then back to the fused distro. Then from there to the amps. You don't need a distro for the grounds, just ground them to the same spot. You wouldn't want to use a fused distro for grounds anyway.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
  2. #17
    Mills561's Avatar
    Mills561 is offline BURR
    Apr 2010
    Palm Beach, Florida
    433
    Quote Originally Posted by jco1385 View Post
    What does running the power wire from the battery to the fuse box and then to the distro do? What would be in the difference in running it straight from the battery to the fused distro?
    Florida Marlins, Miami Dolphins, Miami Heat, Kansas Jayhawks
    SELF PROCLAIMED BIGGEST FAN OF: Ted Ginn, Michael Beasley, Hanley Ramirez
    BOUGHT FROM:
    tristan560
    DARKHART
    tr10av
    dbeez
    wingman0121
  3. #18
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,078
    2 Post(s)
    If you have a problem at the battery end of the wire, it will blow the fuse there rather than 'potentially' burning up your wire and catching fire. It will protect the run of wire from front to back.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  4. #19
    Mills561's Avatar
    Apr 2010
    Palm Beach, Florida
    433
    Appreciate the help my man. Going to order the rest of the necessary install accessories in next couple days and will finally have a nice little setup in my truck. w00tw00t!
    BOUGHT FROM:
    tristan560
    DARKHART
    tr10av
    dbeez
    wingman0121
+ Reply to Thread
  1. Noob question about distro block
    By darkhunter139 in forum Wiring, Electrical and Installation Help
    Last Post: 04-15-2008, 01:20 PM
  2. Noob question about distro block
    Last Post: 04-15-2008, 01:11 PM
  3. Question about distribution blocks...
    By OmegaBunny in forum Amplifiers
    Last Post: 10-14-2007, 12:31 PM
  4. question about dist. block
    By digital mint in forum Wiring, Electrical and Installation Help
    Last Post: 06-24-2005, 02:26 AM
  5. question about distro block
    By dkguitarist in forum Wiring, Electrical and Installation Help
    Last Post: 11-16-2004, 08:17 PM
