Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 53 of 53
Reload Thread: sagging a$$
  1. #46
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,104
    25 Post(s)
    2100 Post(s)
    Re: sagging a$$
    LOL..Hammer some 2x4s in between the springs..lol..i had a friend do that to a 69 chevelle once..it actually worked.
  2. #47
    ewadz3006's Avatar
    ewadz3006 is offline CarAudio.com Elite
    Jan 2012
    erie, PA
    768
    283 Post(s)
    Re: sagging a$$
    Quote Originally Posted by audiobaun View Post
    You can add to your leafsprings,just be careful, and use a jack and maybe a c-clamp for the existing.I lowered mine w shackles from Jegs to level off my truck..was under $100 shipped,but if yo want to raise it,add to leaf springs is cheap, or taller shackles( i think thats what they are called?)Been a couple yrs
    Im pretty sure i have to coil springs in the rear (struts).
    I feel sorry for those who do not drink, when they wake up on the morning that's the best they're going to feel all day.-Frank Sinatra
    2004 mercury mountaineer
    Hu Kenwood excelon x996
    Fronts Incriminator audio comps
    Front amp Aq 120.4
    sub amp Aq2200d
    subs 2 sundown sa 12's @ 32hz
    wiring knu 1/0 ofc
  3. #48
    subzero's Avatar
    subzero is offline CarAudio.com Veteran
    Sep 2008
    Phoenix, AZ
    41
    6,762
    30
    7 Post(s)
    447 Post(s)
    Re: sagging a$$
    Quote Originally Posted by garretttt4 View Post
    Lol I ain't no chubby chaser![COLOR="Silver"]
    Lies.
    2016 Chevy Cruze LT
    Pioneer DD 2700BS ? , JBL MS8 all active , ARC XDI805 channel, FOCAL-100KRS set - active- Dayton Audio SD215A-88 8" DVC Subwoofer as Midbass - sub- Pair of Sundown SD3-12 D2 in 2.6 cubic feet tuned to 27hz., (1) Alpine-MRD-M1000
  4. #49
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    Re: sagging a$$
    try the spring spacers mentioned as they do work, but will wear out the springs faster. Save up $$$ and order custom springs from springworks.com if you plan on keeping it for a while.
    I had 12 batts in the trunk of my altima and it sat level and road fine. Paid around $340 for the custom springs....
  5. #50
    JoiNt-'s Avatar
    JoiNt- is offline Dubstep yo lyfe
    Jul 2012
    Detroit
    27
    172
    74 Post(s)
    Re: sagging a$$
    Think I'm gunna try these.... Did they work good for you?
    i had them on my car for little over a year and they held up fine, w.o em my car looked like i had 8 ppl in the trunk and they kept me at a normal height i def recommend them
    2005 Chevy Colorado ext cab ( back seats removed )
    kenwood DNX6980 DD 4v preouts
    Rockford fosgate PA2 equalizer
    Sub Stage: x2 18" AQ HDC4
    Sub Amp: AQ 3500.1 at .5 ohm
    Enclosure: 8.2 cu ft tuned 29hz
    highs/mids: RF T2 6.5, 1" super dome tweeters
    CA: Rockford Fosgate T800.4
    Electrical: Iraggi 320A HO Alt, 3x XS 3400, Big 3, 2/0 welding cable throughout
    Metered 9/21/12 after install = 153.9 db. 11/2/12 after break-in = 154.4 db
  6. #51
    garretttt4's Avatar
    garretttt4 is offline big pimpin
    Aug 2012
    Watertown sd
    2,456
    1 Post(s)
    1027 Post(s)
    Re: sagging a$$
    Quote Originally Posted by mlstrass View Post
    I'm getting rid of this car as soon as possible lol I hate it .
  7. #52
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,456
    1 Post(s)
    1027 Post(s)
    Re: sagging a$$
    Quote Originally Posted by subzero View Post
    Lies.
    It happens....... Hahaha! Jk
  8. #53
    jockhater2's Avatar
    jockhater2 is offline CarAudio.com Veteran
    Sep 2011
    Saukville, WI
    3,037
    1282 Post(s)
    Re: sagging a$$
    How can you keep the back of your car from riding so low for somewhat cheap???
    Only cost me I think $60. I just swapped my rear springs for stronger ones. Even with 300lbs of equipment and 4 people in the car. The rear only reaches normal ride height at that point.
    Head Unit Pioneer P99RS
    3 Runs of 1/0 OFC Power and 3 Runs of 1/0 OFC Ground
    1 XS Power D3400 & 2 XS Power XP3000 with Copper Bus Bars
    380 Amp & 320 Amp Iraggi Alternators(One is a chevy case, the other ford)
    RD 7500.1 running 2 12 inch SPLaudio (AA Mayhem motors/baskets)
    Tuned to 36 hertz. About 4.5 cubic feet, 8" Aeroport (made by dbeez)
    Zed Audio Leviathan III on Morel MDT-29, RS100-4 & RS225-8 Daytons
    Alex Jones www.infowars.com Endgame, Obama Deception, Truth Rising,
    Fluoride in the water, poison in vaccines, chemical trails in the skyglobal
    elite banks run our government towards a one world global government.
  9. Likes garretttt4 liked this post
  1. Replies: 39
    Last Post: 11-13-2007, 05:23 PM
  2. Calculating Sag and xmax
    By Jlace in forum Subwoofers
    Last Post: 03-26-2007, 08:48 PM
  3. Calculating Sag and xmax
    By Jlace in forum Speakers
  4. calculating woofer sag
    By Crown_amps in forum Home Audio/Video
    Last Post: 03-10-2007, 01:14 PM
