+ Reply to Thread
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 53
Reload Thread: sagging a$$
  1. #31
    JoiNt-'s Avatar
    JoiNt- is offline Dubstep yo lyfe
    Jul 2012
    Detroit
    22
    172
    1 Post(s)
    Re: sagging a$$
    autozone coil spring spacers bout 15 bucks i had some on my car cuz i was draggin *** it wont rly raise u too much, but it def helps u from saggin
    http://images.oreillyauto.com/parts/...pr/18-1201.jpg
    2005 Chevy Colorado ext cab ( back seats removed )
    kenwood DNX6980 DD 4v preouts
    Rockford fosgate PA2 equalizer
    Sub Stage: x2 18" AQ HDC4
    Sub Amp: AQ 3500.1 at .5 ohm
    Enclosure: 8.2 cu ft tuned 29hz
    highs/mids: RF T2 6.5, 1" super dome tweeters
    CA: Rockford Fosgate T800.4
    Electrical: Iraggi 320A HO Alt, 3x XS 3400, Big 3, 2/0 welding cable throughout
    Metered 9/21/12 after install = 153.9 db. 11/2/12 after break-in = 154.4 db
  2. #32
    dragnix's Avatar
    dragnix is offline LXIX
    Dec 2006
    Socal cuz i'm So cool
    19,347
    21 Post(s)
    Re: sagging a$$
    Quote Originally Posted by garretttt4 View Post
    I guess...... I think if rather have a saggy a$$ tho......
    quoted before edit. Damn, you like them saggy asses
    Got a pm regarding my sig
    Quote Originally Posted by audioholic
    please change it to something non-******. thankyou.
  3. #33
    garretttt4's Avatar
    garretttt4 is online now CarAudio.com Veteran
    Aug 2012
    Watertown sd
    2,033
    10 Post(s)
    Re: sagging a$$
    Quote Originally Posted by dragnix View Post
  4. #34
    dragnix's Avatar
    Dec 2006
    19,347
    21 Post(s)
    Re: sagging a$$
    goes perfect with the gif in my sig lol
  5. #35
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,033
    10 Post(s)
    Re: sagging a$$
    She has a vary nice a$$....... :O haha
  6. #36
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,033
    10 Post(s)
    Re: sagging a$$
    Wooo just realized I'm on your sig! Haha
  7. #37
    dragnix's Avatar
    Dec 2006
    19,347
    21 Post(s)
    Re: sagging a$$
    and you like saggy asses lol
  8. #38
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,033
    10 Post(s)
    Re: sagging a$$
    That is what I said I guess...... Lol
  9. #39
    garretttt4's Avatar
    Aug 2012
    Watertown sd
    2,033
    10 Post(s)
    Re: sagging a$$
    Quote Originally Posted by JoiNt- View Post
    Think I'm gunna try these.... Did they work good for you?
  10. #40
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    32
    2,816
    11 Post(s)
    Re: sagging a$$
    I've installed a couple sets and made a set, they should get you back to a normal ride height unless you have literally no suspension left in that case they will do nothing.
    Btw be careful with the spring compression tools keep a very close eye on them while applying tension especially if your using the rentals from autozone/advance auto. The last set I rented didn't have a safety latch on them and when they slip off they become a 5lb missile also watch your fingers don't reach in the spring for any reason unless you don't like those fingers anymore!
    electrical: Optima yellow top, big 3 in stinger 1/0g
    HU: JVC AVX-77 touch screen
    Front stage: RE XXX 6.5" comps
    front stage amp: Rockford T600.2
    subs: 2 Rockford T1 12's,
    sub amp: Rockford T1500.1BDCP
    Enclosure: center port(designed&built by JayDubb757)
  11. Likes garretttt4 liked this post
  12. #41
    J31Rob's Avatar
    J31Rob is offline CarTune Netwerk
    Nov 2006
    Indiana
    11,046
    3 Post(s)
    Re: sagging a$$
    Coilovers are the cheap alternative.
    | www. facebook .com/The.Funk.765 |
  13. #42
    ewadz3006's Avatar
    ewadz3006 is offline CarAudio.com Elite
    Jan 2012
    erie, PA
    737
    7 Post(s)
    Re: sagging a$$
    has anyone suggested taking all the audios out? Cheapest option there is. And if you sell the audios, it's the option that makes you money
    You mus be out yo gawd dan mine!
    I feel sorry for those who do not drink, when they wake up on the morning that's the best they're going to feel all day.-Frank Sinatra
    2004 mercury mountaineer
    Hu Kenwood excelon x996
    Fronts Incriminator audio comps
    Front amp Aq 120.4
    sub amp Aq2200d
    subs 2 sundown sa 12's @ 32hz
    wiring knu 1/0 ofc
  14. #43
    dragnix's Avatar
    Dec 2006
    19,347
    21 Post(s)
    Re: sagging a$$
    Quote Originally Posted by ewadz3006 View Post
    Attachment 26536744
    it's the cheapest option
  15. #44
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,487
    81 Post(s)
    Re: sagging a$$
    I stuffed some high density polyfill in the springs and it helped a ton
  16. #45
    audiobaun's Avatar
    audiobaun is offline Premium Member audiobaun is a Supporting Member of the forum!
    Jun 2011
    rockwall,Tx
    5,919
    36 Post(s)
    Re: sagging a$$
    so no springs? or do they go inside the strut and take the place of the one in the strut? Im asking because my mountaineer is starting to sag and I need to add a few more subs and a bigger box.
    You can add to your leafsprings,just be careful, and use a jack and maybe a c-clamp for the existing.I lowered mine w shackles from Jegs to level off my truck..was under $100 shipped,but if yo want to raise it,add to leaf springs is cheap, or taller shackles( i think thats what they are called?)Been a couple yrs
+ Reply to Thread
  1. Replies: 39
    Last Post: 11-13-2007, 04:23 PM
  2. Calculating Sag and xmax
    By Jlace in forum Subwoofers
    Last Post: 03-26-2007, 07:48 PM
  3. Calculating Sag and xmax
    By Jlace in forum Speakers
  4. calculating woofer sag
    By Crown_amps in forum Home Audio/Video
    Last Post: 03-10-2007, 12:14 PM
