Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 31
Reload Thread: No dash lights
  1. #16
    jrdnhsnbrg's Avatar
    jrdnhsnbrg is offline Pimped my grandma's ride
    Aug 2012
    Eau Claire, WI
    22
    1,877
    689 Post(s)
    Re: No dash lights
    Can we say, thread revival? Haha, no idea. Good luck.
    2013 Ford Flex Ecoboost AWD “Turbo Fridge”
    Shok Triton 15”
    3.8 cubic feet tuned to 32
    DC 1.2k
  2. #17
    robert420's Avatar
    robert420 is offline Senior VIP Member
    Dec 2012
    geneva ne
    338
    86 Post(s)
    Re: No dash lights
    Quote Originally Posted by Demon73 View Post
    Found quick fix. But now the check engine light is on. I grounded one of the lights in the instrument cluster and have lights now! But it caused the check engine light to come on and stays on even after disconecting the ground jumper. Any ideas?
    try disconnecting the battery for a good 30 minutes... it should reset the ECM, switching everything back to the factory default, turning off the light
  3. #18
    jrdnhsnbrg's Avatar
    Aug 2012
    Eau Claire, WI
    22
    1,877
    689 Post(s)
    Re: No dash lights
    Or if you know a mechanic with a code reader have them hook it up and see if it's throwing a code. I think O'Reilly's will run a code scan for free. I just have one in the trunk of my car, I have issues with my transmission that causes the check engine light to turn on occasionally. I clear it quick whenever I get to where I'm going
    Shok Triton 15”
    DC 1.2k
  4. #19
    UsAmpsFreak's Avatar
    UsAmpsFreak is offline Senior VIP Member
    Oct 2013
    North Dakota
    308
    124 Post(s)
    Re: No dash lights
    Quote Originally Posted by jrdnhsnbrg View Post
    Yep as he said take to them and they'll read the code and clear it. You blew a fuse when you installed the aftermarket radio. Don't try to find it by pulling them out and looking at them, it can be blown and not look blown. Use a power probe or a Multimeter.
  5. #20
    robert420's Avatar
    Dec 2012
    geneva ne
    338
    86 Post(s)
    Re: No dash lights
    like i said. disconnect the battery n it should clear the check engine light... simple fix
  6. #21
    jrdnhsnbrg's Avatar
    Aug 2012
    Eau Claire, WI
    22
    1,877
    689 Post(s)
    Re: No dash lights
    Quote Originally Posted by robert420 View Post
    Simple, yes, feasible, no... He will have to go through and reset all his settings the way he wanted them, and depending on how much he changed and what options are available on the car itself it could be a royal PITA, like my car.
    Whatever float's OP's goat, though. No skin off my balls either way
    Shok Triton 15”
    DC 1.2k
  7. #22
    robert420's Avatar
    Dec 2012
    geneva ne
    338
    86 Post(s)
    Re: No dash lights
    i had the problem with my 01 montana. weird thing is when i reconnected the battery the light was off, but my settings were still the same... and i changed alot of things on it and they were still there
  8. #23
    jrdnhsnbrg's Avatar
    Aug 2012
    Eau Claire, WI
    22
    1,877
    689 Post(s)
    Re: No dash lights
    All of my driver settings and HU settings reset if I disconnect my batteries.
    Shok Triton 15”
    DC 1.2k
  9. #24
    robert420's Avatar
    Dec 2012
    geneva ne
    338
    86 Post(s)
    Re: No dash lights
    my HU settings reset yes but none of my vehicle electrical reset
  10. #25
    jrdnhsnbrg's Avatar
    Aug 2012
    Eau Claire, WI
    22
    1,877
    689 Post(s)
    Re: No dash lights
    Like I said, it depends on the vehicle. My old car used to just randomly reset all my settings, it happened about once a month. But it was a GM so I gotta give it a little slack
    Shok Triton 15”
    DC 1.2k
  11. #26
    robert420's Avatar
    Dec 2012
    geneva ne
    338
    86 Post(s)
    Re: No dash lights
    i had a vehicle that did that at random so i said F*** it, ran one wire from a 12v source n put a switch on it. never had any problems after that
  12. #27
    jrdnhsnbrg's Avatar
    Aug 2012
    Eau Claire, WI
    22
    1,877
    689 Post(s)
    Re: No dash lights
    I just sold the car and bought a Lincoln, problem solved
    Shok Triton 15”
    DC 1.2k
  13. #28
    robert420's Avatar
    Dec 2012
    geneva ne
    338
    86 Post(s)
    Re: No dash lights
    i got a 77 mercury. now theres really nothing to worry about resetting since there are no computers in it :P
  14. #29
    jrdnhsnbrg's Avatar
    Aug 2012
    Eau Claire, WI
    22
    1,877
    689 Post(s)
    Re: No dash lights
    EVERYTHING in my car is computerized, even as a 2001... Suspension firmness and steering effort are completely adjustable on the fly, for example. I have a setting that automatically tilts my side mirrors down when I shift into reverse. That's only a few of the functions that I can play with... Cadillac juuust started putting adjustable on-the-fly suspension on their cars a few years ago, yet my 2001 Lincoln has basically the same function, just with air bags instead of magnets.
    Reason #23455 why I love Ford Motor Company vehicles over GM
    Shok Triton 15”
    DC 1.2k
  15. #30
    robert420's Avatar
    Dec 2012
    geneva ne
    338
    86 Post(s)
    Re: No dash lights
    amen. ive never been a fan of gm products. my 01 pontiac montanta has so many things going wrong with it. computer, electrical, mechanical
  1. New Head Unit, No tail/dash lights :(
    By j03sl4ys in forum Wiring, Electrical and Installation Help
    Last Post: 03-18-2011, 02:25 PM
  2. Need quick help, after a new HU and battery, no dash lights?
    By Supergumby5000 in forum Wiring, Electrical and Installation Help
    Last Post: 11-11-2008, 12:45 AM
  3. Illumination wire- No Dash lights
    By tariktchach in forum Wiring, Electrical and Installation Help
    Last Post: 06-08-2007, 02:45 AM
  4. No Dash Lights after install??
    By maco in forum Wiring, Electrical and Installation Help
    Last Post: 01-31-2007, 12:18 PM
  5. No Dash Lights! Dimmer Switch Blown?
    By Cutlass87 in forum Wiring, Electrical and Installation Help
    Last Post: 03-16-2004, 04:29 AM
