+ Reply to Thread
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 51 of 51
Reload Thread: accidently hooked ground and power up backwards
  1. #46
    groundpound4200's Avatar
    groundpound4200 is offline Da fuq did I just read?
    Nov 2007
    Mankato, MN
    27
    5,252
    4 Post(s)
    Re: accidently hooked ground and power up backwards
    the Insignia guy was on some good drugs that day
    2007 Honda Pilot 2008 Nissan Maxima
    2 RD D9s strapped @ 1 ohm Sundown SAZ-1500D V.3
    2 Sundown Nightshade V.2s 2 10" Atomic APX
    Sundown SAX-125.2 x 2 Sundown SAX-100.4
    Sundown NeoPro 6.5"s, JL ZR Tweets Sundown NeoPros
    RIP Taylor aka NewAgeKing, you are missed!
  2. #47
    Babykinns's Avatar
    Babykinns is offline Member
    Oct 2012
    Nelsonville, OH
    55
    Quote Originally Posted by groundpound4200 View Post
    lol it was yesterday and I was going to run it on low because thats what I thought it was suppose to go on
  3. #48
    Nov 2007
    Mankato, MN
    27
    5,252
    4 Post(s)
    it is...
  4. #49
    Babykinns's Avatar
    Oct 2012
    Nelsonville, OH
    55
    it is...
    I have 2 more questions about this b4 I throw in the towel. If the power line fuse blew could it still look normal like nothing is wrong with it? Also if the fuse is blown should that keep my amp from coming on at all? Like for instance if the power line fuse is blown should my amp still come on even though its going straight into protect mode?
    When I unhook the rca's and the speaker wires the amp will come on the protect light will come on then go back off but the green light don't come on at all. So it kinda makes me feel like the only power its really getting is from the rca's and the signal wire?
  5. #50
    Nov 2007
    Mankato, MN
    27
    5,252
    4 Post(s)
    Fuses can blow sometimes and still look ok but not very often. You can check for continuity through the fuse with a multimeter if you have one to see if it's blown. I've never seen an amp try and turn on without a live power wire hooked up though.
  6. #51
    Babykinns's Avatar
    Oct 2012
    Nelsonville, OH
    55
    Quote Originally Posted by gckless View Post
    Oh, those small fuses definitely should have blown first. What size wire?
    Somehow this turned out to be the ground wire, which worked fine b4 this all happened lmfao.
+ Reply to Thread
