I did this to my old Orion HCCA 275G4 by hooking it up in the darkit played for about 2 minutes after I replaced all the fuses before she shut down for good. It still gives me a sick feeling in my stomach thinking about it.
2007 Honda Pilot 2008 Nissan Maxima
2 RD D9s strapped @ 1 ohm Sundown SAZ-1500D V.3
2 Sundown Nightshade V.2s 2 10" Atomic APX
Sundown SAX-125.2 x 2 Sundown SAX-100.4
Sundown NeoPro 6.5"s, JL ZR Tweets Sundown NeoPros
RIP Taylor aka NewAgeKing, you are missed!
I done this being in a rush not that long ago, and fried my DTR 1700... reason I no longer run the same colour power and ground wires.. All I can say is slow down and take your time next time.. Lesson learned...
2007 Chevy Impala LT
HU: Clarion CZ500 Front Speakers: CDT HD6.1
Sub: 12" Hispl Custom Shocker Extreme Box: 1.9 cubes net tuned to 32hz Amp: Sub: EarthQuake 2k @2ohm / Front Stage: Zapco 350
Sold To: Spooney x1 , Bgfx x1, garychoffmann x1 Bought From: ssteele18 x 1 , Louisiana_CRX x1 , mylows x3 , Spooney x4 , Bettr n' Revrse x1 , draginx x1 , CerwinVega_Fan x1 , infamous_e46 x2 , mclerico83 x1 , argent_audio x1 , Whitedragon551 x1 , Vertex Audio x3, Buck "box designs" x2 , RAM_Designs "box design" Traded With: infamous_e46 x1 , Spooney x4 "repair of amp x2"
anybody know how much it would cost to get fixed?
Enough to buy a new one.
Youll probably be much cheaper off to just buy a new one. Maybe read around on here and find a deal on a used but better one in the same price range?
Did you ever check all of your fuses?
yeh not sure if the ones i tried swapping them out with are any good or not tho but the fuses in it dont seem any different than they were when they were workin
Had a color blind friend hook up one of my old fosgates this way, let out the magic smoke, He then informed me of his colorblindness
---------- Post added at 07:26 PM ---------- Previous post was at 07:25 PM ----------
if you have a volt meter, put it on ohms and read across the fuse
You're getting 12V or more from the battery at the amp terminals?
Is this the first time you hooked it up or was it hooked up before this? What are your subs wired like? What subs, dual voice coil or single, what's their resistance? That amp is a 2 ohm minimum, if you wired down to 1 that would be why. Disconnect the subs and turn on the amp, does it still go into protect?
2 12" kicker cvr's im pretty sure they're dual voice coils they're in a ported box wire at 2ohms rated at 400 watts rms - 800 watts rms max ea i tried disconnecting the subs it still goes into protect cant do anymore checking tonight bcuz the **** cable that goes to the hood lever broke so i cant pop my hood just aint my day today
Ive actually done this on two different amps and both of them were fone. On a jl audio 500.1. And it blew the inline fuse, worked fine after replacing that and a jbl bp300.1 blew the amp fuses, replaced them and it worked fine
Yep, it happens. And its things like this that demonstrate the necessity and usefulness of inline fuses. The amp is usually fine because the fuse blows before the amp sees current it can't handle. Those wouldn't have been there, and you better have hoped you had a fire extinguisher handy.
OP said he checked all fuses though and all were fine.
Bookmarks
