Results 1 to 15 of 15
Reload Thread: 2 ohm DVC question
    jstro13's Avatar
    jstro13 is offline Junior Member
    Oct 2012
    Collinsville, IL
    2 Post(s)
    2 ohm DVC question
    I just purchased an alpine type r DVC 2ohm sub and am trying to figure out the best way to wire it. I have a 1000 watt kenwood amp. How could i get the most power out of this set up? Thank you for your help!
    This is the sub : Alpine - SWR-10D2
    This is the amp : Kenwood - KAC-8105D
    rebelfromva's Avatar
    rebelfromva is offline CarAudio.com Veteran
    Jun 2011
    VA
    3,818
    1605 Post(s)
    Re: 2 ohm DVC question
    can be wired to 1 or 4
    09 Cobalt LT
    Headunit -Alpine CDA-9887
    Front Stage - PHD FB 6.1 PRO SIX M/B, FB 5.1 m/b, FB 1.1b tweets
    Highs amp -Pheonix Gold Xenon 100.4 & 200.4
    Sub stage - 2 DC M2 LVL 5 12s
    Sub amp - 2 DC 5.0Ks
    Electrical - Singer 270 alt, big 3 0/1 & 12g ofc audio technix, 2 XS d3400s
    Deadener - 80 mill Audiotechnix deadener
    "Trunk hit hard like Kimbo Slice"
    TEAM DC AUDIO
    jstro13's Avatar
    Oct 2012
    Collinsville, IL
    2 Post(s)
    so there's no way that it could be wired to 2 ohms?
    I edited the original post with more info on the exact sub/amp
    Sub Bass Woofrz's Avatar
    Sub Bass Woofrz is offline Senior VIP Member
    Aug 2012
    Camas, WA
    336
    140 Post(s)
    well if your amp is one ohm stable then you would wire it in parallel down to a 1 ohm load, if your amp is not 1 ohm stable then you need to wire it in series to a 4 ohm load.
    Aug 2012
    Camas, WA
    336
    140 Post(s)
    looks like that amp is not 1 ohm stable, so you should wire it in series to 4 ohm. This will be fine until you get a new amp or change the sub
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Subwoofer Wiring Diagrams, One 2 ohm Dual Voice Coil (DVC) Speaker
    I'd go wire to 4ohm. Agree with it not being very reliable at 1ohm.
    jstro13's Avatar
    Oct 2012
    Collinsville, IL
    2 Post(s)
    So why exactly would it be incapable of being wired at 2 ohm? is it because each coil is 2 ohm and would have to be wired together to be amplified? Would it be best if I just returned it and got a 4 Ohm model?
    Sorry, I'm new to this and want to learn as much as possible
    Falcons's Avatar
    Falcons is offline that **** i dont like
    Jan 2011
    Albion, New York, United States
    5,446
    1499 Post(s)
    why would you buy something not knowing what your buying or how it works?
    People complained about my sig so I changed it.
  9. #9
    Jan 2007
    any wet spot i can find
    3,282
    1188 Post(s)
    Quote Originally Posted by jstro13 View Post
    I hate to be the one....but, no you do not own a 1000 watt amp. You own a 500 watt rms at 2 ohm or a 300 watt rms at 4 ohm amp...and I am skeptical of those ratings as well.
    Kenwood - kac-8105d
    the sub can be wired to 4 ohm with the voice coils wired in series, OR, 1 ohm with them wired parallel. Your ONLY option with that amp is to wire the sub in 4 ohm fashion for 300w..........
    ......*****, huh?
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  10. #10
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,421
    141 Post(s)
    1 Thread(s)
    6008 Post(s)
    return the sub for a dual 4 ohm sub
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  11. #11
    neo_styles's Avatar
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Unfortunately you fell victim to subwoofer advertising at its worst. Most sites advertise PEAK wattage. So if you're looking at true specs of the Kenwood, it's 1000W peak and only 500 Wrms. Next time make sure to look at the RMS figure and match it to whatever sub you're intending to buy.
  12. #12
    Jan 2007
    3,282
    1188 Post(s)
    take it all back and come to school to learn what can be had for the same $...far better equipment.
  13. #13
    jstro13's Avatar
    Oct 2012
    Collinsville, IL
    2 Post(s)
    I knew that it was 1000 watt peak. I just didn't know which way I'd be able to get the most out of the amp/sub combo. The amp was actually given to me by a friend. So no money lost there.
  14. #14
    neo_styles's Avatar
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Then you're in a better situation than you originally thought. At least you're still looking at 300wrms at 4 ohms which is at the bottom handling range of that sub. Should still be ok. Just not gonna come close to 1000W with that amp.
  15. #15
    jstro13's Avatar
    Oct 2012
    Collinsville, IL
    2 Post(s)
    However, the 4 ohm DVC version would draw more power from the amp if wired parallel?
  1. question about 4 ohm dvc subs
    By Turd Ferguson in forum Subwoofers
    Last Post: 06-01-2010, 04:01 PM
  2. Question about wiring 2 , 2 ohm DVC
    By vandiar2 in forum Subwoofers
    Last Post: 12-02-2008, 05:09 PM
  3. Question, Wiring (2) 2-ohm DVC subs??
    By SuperTrooper in forum Wiring, Electrical and Installation Help
    Last Post: 08-18-2007, 07:43 PM
  4. Question on 2 ohm DVC and 4 ohm DVC
    By xpl0it in forum Subwoofers
    Last Post: 06-25-2006, 12:37 AM
  5. Ohm DVC Amp Question
    By djvi0lent in forum Amplifiers
    Last Post: 04-01-2004, 12:11 AM
