Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
Re: Why is my amp going into PROTECT
What size wire you running? Got good terminal connections too ? Where ya grounded at?
Originally Posted by
Spooney
If your electrical can't handle 500 watts how do you plan on running 4 times that power?
Im dying to hear the answer. lol
Electrical- 200amp alt- Optima yellow tops front+back- stinger 10 farad cap- cadence 1/0awg+stinger+knu fuses
Head unit- Pioneer 9400bh
EQ- Audiocontrol Four.1
Active x/over- Audiocontrol 6xs
Front stage-B.A pro 50se (in sealed centrapod)
Soundbar- Jbl p652 (NOT for long)
Midbass- Jl cw800 (in sealed intrapod)
Subs- 1 RExxx 12 in cust tuned 33hz box@1ohm (thank u Mobile Enclosures)
Amps- Sub-Orion hcca 2500.1/ Midbass-Alpine pdx 2.150/Components- Alpine pdx 4.150
keep the engine @7000 rpm's and never EVER turn the lights on.
I always start a installation with a better ground wire, from the engine to the chasis and from the chasis to the battery and from the alt to the + battery. Do that before you install a bigger amp.
Spooney
^^^This. If you actually put that in, you better not turn that thing up, or you'll cook it when your voltage drops to lower than what you are seeing now.
By Weeznur32 in forum Amplifiers
Last Post: 06-02-2012, 03:57 AM
By 86vette07 in forum Amplifiers
Last Post: 07-02-2009, 12:22 AM
By hardrockfan in forum General Discussion
Last Post: 12-24-2004, 04:42 AM
By B|2imstone in forum Amplifiers
Last Post: 12-08-2003, 03:12 AM
By Juice in forum Amplifiers
Last Post: 12-05-2003, 12:05 PM
Tags for this Thread
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
