Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Reload Thread: Big 3, most important?
  1. #16
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Re: Big 3, most important?
    The smallest of the big 3 in most cars is the neg battery to body wire. It's also the shortest and usually easiest to replace. Alt to battery + would be second. The cable from bat to engine block has to carry starter current so it's usually pretty beefy. That one would be last on the priority list.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  2. #17
    Jan 2007
    any wet spot i can find
    3,282
    1188 Post(s)
    Quote Originally Posted by maylar View Post
    I always figured the engine block to chassis ground had to be the same as the Alt to batt., since the Alt case to alt bracket serves as the alt ground...or am I totally wrong here?
    "Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
  3. #18
    maylar's Avatar
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Quote Originally Posted by quackhead View Post
    Technically that's 2 of the 3 wires combined. Factory wiring goes from battery negative terminal to the engine block (1 wire) and from battery negative to the body (another wire). You are correct that the first wire also carries return current from the alternator, but starter current is the determining factor in the stock wire gage. Getting the alt/bat current to the chassis is the function of a separate wire and it's often pretty small - I think my 85 Olds had a 10 gage there. So in terms of priority, I'd do the skinny ones first.
    dave
  4. #19
    rebelfromva's Avatar
    rebelfromva is offline CarAudio.com Veteran
    Jun 2011
    VA
    3,818
    1605 Post(s)
    big 3 is not need for that setup...
    09 Cobalt LT
    Headunit -Alpine CDA-9887
    Front Stage - PHD FB 6.1 PRO SIX M/B, FB 5.1 m/b, FB 1.1b tweets
    Highs amp -Pheonix Gold Xenon 100.4 & 200.4
    Sub stage - 2 DC M2 LVL 5 12s
    Sub amp - 2 DC 5.0Ks
    Electrical - Singer 270 alt, big 3 0/1 & 12g ofc audio technix, 2 XS d3400s
    Deadener - 80 mill Audiotechnix deadener
    "Trunk hit hard like Kimbo Slice"
    TEAM DC AUDIO
  5. #20
    sbelew's Avatar
    sbelew is offline Senior VIP Member
    Sep 2010
    New Port Richey, FL
    51
    213
    40 Post(s)
    So for learnings sake, at what point would you guys recommend upgrading in terms of wattage for;
    Big Three Upgrade?
    Battery Upgrade?
    Alternator Upgrade?
    Vehicle: '99 Ford F-150 Extended Cab / '98 Chevy Cavalier LS
    Head Unit: Kenwood KDC-X997 / Kenwood KIV-BT900 w/ HD Radio
    Sub: FI Audio x12 4ohm w/BP 1cu ft sealed / 2 GTO804's 1.4 cu ft @28Hz
    Sub Amp: Hifonics BRZ1700.1d /
    Front Door Speakers: Massive Audio CK6 / Massive Audio CK6x
    Rear Door Speakers: Boston Acoustics SL80 / Massive Audio VX69
    Amp: MBQuart DSC4125 / Massive Audio NX5
    Wiring: All Knukonceptz
    Sound Deadening: eDead 45 / AT60 / Murder mat BL
    References: Retroaudioinc, davidtemple, cd6551, double07, Ssteele18
  6. #21
    Jun 2011
    VA
    3,818
    1605 Post(s)
    Big 3-1000
    Add second batt-1500
    Alt -3k plus
    09 Cobalt LT
    TEAM DC AUDIO
  7. #22
    DukeNut's Avatar
    DukeNut is offline Senior VIP Member
    Nov 2008
    Ohio
    313
    20 Post(s)
    totally agree with maylar here. if you think about it, you use the pos from battery to amp and then ground the amp to body, so this is where the circuit (body to battery) is completed. i actually experienced this with helping the dimming issues on my son's car before doing the other 2 a few days later.
    Refs:
    jshak07, photocrazy8, DARKHART, dadon, enzowho
  1. Replies: 138
    Last Post: 07-14-2008, 01:21 PM
  2. Most Important Wire
    By CarlB in forum General Discussion
    Last Post: 12-21-2004, 11:44 AM
  3. Most Important Part of System?
    By sungwei in forum General Discussion
    Last Post: 04-06-2004, 02:34 AM
  4. Replies: 98
    Last Post: 03-29-2004, 02:45 AM
