+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 38 of 38
Reload Thread: Re installing Audio Set Up
  1. #31
    jungstah's Avatar
    jungstah is offline Senior VIP Member
    May 2012
    san francisco
    278
    2 Post(s)
    Re: Re installing Audio Set Up
    make sure your headunit is turned up as well
    Pioneer AVH-P2400BT
    Stock Pioneer 4" components
    Hifonics Brutus BRZ1700.1D
    Two SA-12's
    cruddy prefab ported box----new box otw
  2. #32
    DanOpi's Avatar
    DanOpi is offline Member
    Mar 2011
    MN
    54
    It was up. 80% of the maximum value. 50.
  3. #33
    DanOpi's Avatar
    Mar 2011
    MN
    54
    Should each speaker be 17.32 Volts or should the total be 17.32?
  4. #34
    Joe89's Avatar
    Joe89 is offline Senior VIP Member
    Dec 2007
    Northern California
    267
    If someone else wants to chime in and prove me wrong, by all means do so...
    but you want 17.32v per channel.
    You can always try setting them by ear, but perhaps you need a line driver or something of that nature.
  5. #35
    DanOpi's Avatar
    Mar 2011
    MN
    54
    Still only getting around 9.8 Volts per channel. Tried with a new mmt too. At a loss of what to do
  6. #36
    Joe89's Avatar
    Dec 2007
    Northern California
    267
    Is every feature on the head unit off? Equalizer on flat? High pass filter on your amp selected?
  7. #37
    DanOpi's Avatar
    Mar 2011
    MN
    54
    Yes and yes.
  8. #38
    Joe89's Avatar
    Dec 2007
    Northern California
    267
    Well unless someone else can chime in, if I were you, I would try to set it by ear.
    Connect your speakers, put your amp level knob at the lowest setting, headunit to 80% of max.
    Play the 1kHz tone on repeat, and slowly bump up the level until you can hear a pitch shift (clipping) or distortion. Readjust the amp level so it is slightly below clipping/distorting level.
    Then play some of your music. If it sounds distortion free, I think you have successfully set your gain.
+ Reply to Thread
  1. opinion on home audio set up please
    By cstabler in forum Home Audio/Video
    Last Post: 10-22-2005, 08:40 PM
  2. Ford Superduty audio Set Up Help
    By ducster1 in forum General Discussion
    Last Post: 06-20-2005, 03:40 PM
  3. Can i see your audio set up?
    By coolrolla in forum General Discussion
    Last Post: 02-14-2003, 11:53 PM
  4. Any suggestions for an audio set-up?
    By 98RangerOwner in forum Wiring, Electrical and Installation Help
    Last Post: 07-03-2002, 12:04 AM
  5. Newbie at Car Audio set ups...Got a general Question..
    By <FakeFUBU05> in forum Subwoofers
    Last Post: 12-18-2001, 09:36 PM
