Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Reload Thread: Alternator Voltage: Bad or Awesome?
  1. #16
    BlurredVision's Avatar
    BlurredVision is offline CarAudio.com Elite
    Jan 2008
    Greenville, NC
    30
    667
    119 Post(s)
    Re: Alternator Voltage: Bad or Awesome?
    Quote Originally Posted by gckless View Post
    So you never seen any issues?
    My trunk is about .1~.2V less than my underhood meter, indicating either improperly set meters or a less than optimal ground. I'm not too concerned witht that right now though.
    I thought this was normal? Gotta add in all the resistance from various places
    Current Vehicle: 2012 Honda Accord LX
    Sound Deadening: NVX 90mil
    Radio: Pioneer AVH-4200 NEX
    Front Stage: Ampere Audio AA-6.5 Componenet Set
    Rear: Ampere Audio AA-6.5SC Coaxial Set
    Subwoofers: 2 Sundown Audio X 12 V2
    Amps: Ampere Audio AA-125.4 And Ampere Audio 3800.1 @ 1 Ohm
    Batteries: 2x Duracell G31
    Wiring: 0, 4 And 8 Awg Welding Wire
    Alternator: Mechman 240
  2. #17
    ummduh's Avatar
    ummduh is offline Member
    Nov 2009
    Bay Area, CA
    54
    12 Post(s)
    Running a 12v battery into the 15range is pretty hard on it. You're definitely shortening its life.
    Car electronics are generally going to live up to 16v or so. It's of course not recommended but they are able to handle it. You'd need a 16v battery to do that, though.
    I personally wouldn't run past 14.8v myself. Just cuz I don't have the money to play with the big boys like that. Haha.
  3. #18
    ummduh's Avatar
    Nov 2009
    Bay Area, CA
    54
    12 Post(s)
    Quote Originally Posted by BlurredVision View Post
    Yea its called voltage drop and 10% is usually the max drop allowed.
  4. #19
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Quote Originally Posted by ummduh View Post
    Yeah, really at 15V I'm not too worried about my car electronics, I'm fairly certain they will survive with no issues. However, my battery is where I'm concerned. I have a Yellow Top. I have read that for standard batteries, voltage that high may cause excessive gassing and the like. Since this is a sealed deep-cycle, will I see the same problems? I'm going to shoot an email to DC Power soon, see what they have to say. Probably should have done that already.
  5. #20
    akheathen's Avatar
    akheathen is offline trianoacitol contraceptiv akheathen is a Supporting Member of the forum!
    Jan 2011
    Anchorage AK
    36
    2,355
    1 Post(s)
    250 Post(s)
    yellow top won't like it at all. i've seen them swell like a bag of crayola marshmallows off stock 160a delphi. check your connections. a slight connection problem at the plug, or fuse panel will tell the ecm to tell the alt. to charge more. used to have mine run up in the 15.x range. keeping it at 14.4 nominal, only spikes 14.9 with small load recovery, haven't thrown a huge load on it and then measured with the fluke yet. i was just checking on some off-gassing i thought i smelled.
    *IF I have forgotten to exchange feedback, please let me know*
    i buy broken amps....
    No, i will not "gift" paypal. please do not even make it awkward by asking. if the fees are an issue, I am usually inclined to add them. unless you have discount elsewhere, shipping is through usps flat rate, through usps parcel post, or through the roof..... i am in alaska. thanks
    -Heath H-
  6. #21
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    its fine
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  7. #22
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    So this is what DC Power had to say in reply to my email:
    "My suggestion would be to try a different battery, optima yellow tops tend to have some charging issues with higher output alternators. There could be a chemical imbalance in the battery since they're prone to that. If you have any questions let us know.
    15 volts is fine but you don't want anything higher..."
    Thoughts?
  8. #23
    muskyhunter567's Avatar
    muskyhunter567 is offline Truck Do Burn Rubber
    Apr 2008
    Milwaukee Wisconin
    348
    5 Post(s)
    i had 6 stinger spv70s in my car plus a red top under the hood and they were pretty cool charging up around 15-15.5v but once you got into that 16+ mark, they would start venting and hissing and stinking up the place, I would only charge the bank of batteries that high if i was at a show and wanted to get max volts right before a run, but I had the stingers in my car for over a year, and i still use three of them in my boat, they seem just fine to me, still hold a good charge and do what there are supposed to.
    2003 subaru forester, totally stockish and super lame but working on it
    used to compete spl, trying this SQ thingy with the subaru, need sq gear.
    ROE Muskyhunter5675
    God Is Love And Love Is Real
  9. #24
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Quote Originally Posted by muskyhunter567 View Post
    That's good news. I've been watching my voltage, and it's been pretty consistent. When I first start it, when it's cold, it will run at 15.3V. Once it's warm, after driving for 10 minutes at least, it will drop down to 14.9V, and down to about 14.7 if it's warmer. I think I am just going to roll with this, and not worry too much about getting an external regulator, provided my amps will not have fits about voltage that high. I still haven't put my DC's on there, waiting on Level 3's to get in. I don't see that being a problem though.
  10. #25
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    27
    3,488
    862 Post(s)
    I think you're definitely fine, once it warms up. YellowTops aren't really the ideal car audio battery anyways. Just keep it going, if the battery goes bad, replace it with a more ideal battery. Otherwise just keep doing your thing. I don't think the amps will have any issues with that voltage either.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  11. #26
    Apr 2008
    Milwaukee Wisconin
    348
    5 Post(s)
    yea, you will be ok, those voltages are fine, I ran incriminators in my car so i never had to worry about to high a voltage or two low, they just worked all the time no matter what, I love those amps, but I did just get a kicker 75x4 and it shuts off around the high 15s and it gets really annoyying just listening to my bass and no vocals
    ROE Muskyhunter5675
  12. #27
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Well, I just ordered a 80PRS, and noticed the manual says that the voltage limit is 15.1V. Has anyone seen issues with theirs?
  1. checking alternator voltage\amperage?
    By req in forum Wiring, Electrical and Installation Help
    Last Post: 10-10-2004, 12:59 AM
  2. preamp voltage, rms or peak?...
    By slick316 in forum General Discussion
    Last Post: 12-04-2003, 05:04 PM
  3. perfects in a trunk good/bad? or go with type R?
    By Quiksilver in forum Subwoofers
    Last Post: 04-29-2002, 12:26 AM
  4. X-Plod???bad or good
    By <XploD> in forum General Discussion
    Last Post: 01-05-2002, 11:58 PM
