Results 1 to 5 of 5
Reload Thread: Bridging 4 Channel Amp to 2 SVC Subs...Single Speaker Terminal? (Quick and Easy)
    jts4486's Avatar
    jts4486 is offline Junior Member
    Jan 2006
    Twin Cities, MN
    28
    5 Post(s)
    After a quick search I couldn't seem to find an answer so my appologies if it has been answered before/recently.
    I am helping a friend on a very budget install using a 4 channel amp to two 4 ohm single voice coil woofers.
    Bridging fronts to one sub, and rears to the other sub, seperate chambers.
    My question revolves around the speaker terminal. Is it possible to only use a single speaker terminal?
    Would it be simply both positive outs from amp to positive speaker terminal input and 2 runs on the back side to the positives of the woofers? (and the same for the negatives.)
    Or would this not work?
    Thanks for your help!
    jts4486's Avatar
    Jan 2006
    Twin Cities, MN
    28
    5 Post(s)
    Icon11 Re: Bridging 4 Channel Amp to 2 SVC Subs...Single Speaker Terminal? (Quick and Easy)
    Anybody?
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    Quote Originally Posted by jts4486 View Post
    Anybody?
    find a manual on line for what ever amp you are using. or just look to see if it says "bridged" above the terminals.
    sometimes it's put on the amp, like so....
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  4. Likes West liked this post
  5. #4
    ancorp's Avatar
    ancorp is offline Senior VIP Member
    May 2011
    Toronto
    227
    1 Post(s)
    61 Post(s)
    No you cannot use one terminal. You need four wires running to the amp. Two positives and to negatives.
  6. #5
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,238
    25 Post(s)
    2150 Post(s)
    You will need to choose to use ch 1 and 2, or 3 and 4, to bridge to run in mono/bridged mode on the subs,as long as the amp can handle a 2ohm bridged mode if using 2 svc 4ohm subs.Other than that,you can run two DVC 4ohm subs in a 4ohm bridged mode also,last and least..one svc sub to ea ch, of 1 and 2, or 3and 4 , in stereo mode.
  1. wiring 2 channel amp to 1 sub
    By shortys408 in forum Amplifiers
    Last Post: 05-08-2005, 11:41 AM
  2. Need Help Bridging 2 Amps to 1 Sub
    By WrecklessDryva in forum Amplifiers
    Last Post: 05-14-2004, 08:27 PM
  3. Need Help Bridging 2 Amps to 1 Sub
    By WrecklessDryva in forum Wiring, Electrical and Installation Help
    Last Post: 05-01-2004, 09:28 AM
  4. 2 Channel Amp to 2 4 Ohm Speakers
    By photai in forum Wiring, Electrical and Installation Help
    Last Post: 01-28-2004, 11:23 AM
  5. 4 Channel amp to one sub?
    By Daniel in forum Amplifiers
    Last Post: 10-30-2002, 08:31 PM
