Re: Wire batteries in series or parallel
Originally Posted by
TDot
Thanks, I kind of expect the back to draw from the front at start by the nature of the set up. The quetion is, why is this a problem? I would expect if it was serious there would be a ready made work around. Can something be damaged? What are adverse consequences of this? How bad can it really be? GENERALLY how long would it take for the battery to charge back up? Would a capacitor inbetween the batteries help/remedy the issue?
1. No. A capacitor would not help. It would be completely unncessary.
2. Don't get a battery isolator. You don't need it. A battery isolator is only used if you plan on playing music when the car is off. Which is dumb because you still have to start your car every 15-30 minutes to charge the battery. Its a waste. And the low voltage to your amp if you don't monitor it can be dangerous.
3. To wire a battery in parallel just run 1/0 OFC wire from the front positive to the rear batteries positive. And for the negative you should do the same. But if you can't. Then ground the front battery to the frame (should already be done) and do the same for the rear.
Head Unit Pioneer P99RS
3 Runs of 1/0 OFC Power and 3 Runs of 1/0 OFC Ground
1 XS Power D3400 & 2 XS Power XP3000 with Copper Bus Bars
380 Amp & 320 Amp Iraggi Alternators(One is a chevy case, the other ford)
RD 7500.1 running 2 12 inch Ascendant Audio Mayhems (might go up for sale)
Tuned to 36 hertz. About 4.5 cubic feet, 8" Aeroport (made by dbeez)
Audison LRx 6.9k on Morel MDT-29, RS100-4 & RS225-8 Daytons
Alex Jones www.infowars.com Endgame, Obama Deception, Truth Rising,
Fluoride in the water, poison in vaccines, chemical trails in the skyglobal
elite banks run our government towards a one world global government.
Bookmarks
