Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Reload Thread: Headunit is over heating ..Please Help..
  1. #16
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    37
    2,834
    1 Post(s)
    864 Post(s)
    Re: Headunit is over heating ..Please Help..
    Quote Originally Posted by West View Post
    You need the adapter to get an RCA out on that deck.
    Oh it's one of those, OP go get a new HU with some pre-outs it makes life a whole lot easier!
    electrical: Optima yellow top X 2 big 3 in monster OFC 1/0g high output alt by maniac electrics
    HU: JVC AVX-77 touch screen
    Front stage: RE XXX 6.5" comps
    front stage amp: Rockford T600.2
    subs: 1 Sundown ZV4 12"
    sub amp: Rockford T2500.1BDCP
    Enclosure: ported (by JayDubb757 )
  2. #17
    West's Avatar
    West is offline Banned
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Quote Originally Posted by vaiboy View Post
    He doesn't need a line level converter the amp is set up like the JL slash amps that can accept speaker level through the RCAs, the high level signal also triggers the amp turn on. His problem is probably the length of the RCAs vs. their gauge, they are probably 20-22 gauge. There's probably only 2-3 amps at less than 8V running through those cables but that is just a bit too much to run the length of an SUV. If he used some 14-16 gauge speaker wire to tap into the signal behind the head unit then connected the RCAs to the 14-16ga at the amp there wouldn't be any problem with the current. Of course this is assuming he has everything connected correctly behind the head unit.
    If your familiar with it I'll bow out.
    ---------- Post added at 01:32 PM ---------- Previous post was at 01:32 PM ----------
    [/COLOR]
    Quote Originally Posted by goingdef View Post
    This definitely solves the problem.
  3. #18
    mike11872's Avatar
    mike11872 is offline Junior Member
    Aug 2012
    new york
    5 Post(s)
    thanks west...yes..my amp is Pioneer GM-D7500M
  4. #19
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Quote Originally Posted by mike11872 View Post
    Do you have the part in bold?
    What's in the box?
    Mono amplifier with 40-amp ATO fuse inserted
    9.5" Speaker-level input harness (with stereo RCA plugs on one end and bare wire on the other end)
    4 Self-tapping screws (length=3/4")
    Owner's Manual (En/Sp/Fr)
    Warranty sheet (En/Fr)
  5. #20
    mike11872's Avatar
    Aug 2012
    new york
    5 Post(s)
    hey west... according to your suggestion, i should use 8 awg speaker wire to tape with my rear speaker output wire and run them into convertor, and then use rca between amp and convertor, right? thanks expert
  6. #21
    Flex68's Avatar
    Flex68 is offline dilligaf
    Jan 2012
    The Backroads
    1,613
    558 Post(s)
    Quote Originally Posted by Jaguar View Post
    I'm confused, why are you using tape at all? It is not uncommon for HU's to get hot, especially after ''extended play''. Ie: 1 or 2 hours.
    Another factor is we are still in the middle of summer, even if you pull your HU out when it's this hot it's likely your HU will still be hot.
    Mine was. HU's have heat sink cases for a reason. Anyways, be sure of one thing after you are done cramming everything back in no
    matter what you do, make sure none of the wires are too close or against the head unit, the plastic could literally melt off your RCA'S...
    lmao
    "Confused" but still attempting to offer advice on something u clearly haven't a clue about...
    Weak, as always!
    Quote Originally Posted by Spider Monkey View Post
    Romney will [fornicate] me less than Obama already has and WAY less than what Obama has planned.
    Refs: adamtwo4, basscort2009, burzendowski, clanassa, cthedinger, ikoolguy, its_bacon12, Jew_Bagel, jr711, kreapin, kowboy, Rudy, TheRealDefman, Winter_C
    HU:Eclipse CD7200 MkII
    Subs: Fack Skar Audio
    Front comps: HAT Clarus C61-2 off Sony ES 7547
    Electrical: C&D batt, Big 3 with 1/0, 4ga to amps, Stinger RCA’s
    Damping: 60mil FG panels over holes, full worx from SDS
  7. Dislikes Jaguar disliked this post
  8. #22
    mike11872's Avatar
    Aug 2012
    new york
    5 Post(s)
    Yes, in the box are following included,
  9. #23
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,703
    1406 Post(s)
    Something like that should work. If you use the converter that came with the amp that should be the way 2 go. Go and get some proper wire connectors so it doesn't come undone. I kind of misunderstood the problem initially. I am not used to amps like that, it concerned me a lot I don't want people to have there stuff break...
    Good luck man!
  10. Likes Jaguar liked this post
  11. #24
    vaiboy's Avatar
    vaiboy is offline Senior VIP Member
    Sep 2006
    Phoenix, AZ
    274
    37 Post(s)
    8awg is beyond overkill for this, 14-16awg is all you need. Connect one side behind the head unit then connect the "9.5" Speaker-level input harness" to the other end. Plug the RCA end into the amp and you should be all set.
  1. Primer is a disaster...PLEASE HELP!
    By bcarpenterfhl in forum Enclosure Design & Construction Help
    Last Post: 02-14-2005, 01:12 AM
  2. what is big 3.. please help Newbie ..
    By edmonton_mr2 in forum Wiring, Electrical and Installation Help
    Last Post: 11-19-2004, 08:24 PM
  3. Directed 1100D Amp is over heating?
    By Tupac2413 in forum Amplifiers
    Last Post: 07-21-2004, 06:05 PM
  4. my amp is over heating
    By thegunner in forum Wiring, Electrical and Installation Help
    Last Post: 08-21-2002, 03:35 PM
  5. Is This Cheap? Please Help...
    By b1utigg3r2 in forum General Discussion
    Last Post: 04-08-2002, 03:08 PM
