Results 1 to 3 of 3
Reload Thread: Please help me with my amplifier settings, Thank you!
    Oct 2009
    Seattle, WA
    35
    2 Post(s)
    In the trunk of my mustang I built a spare tire box with 3 kenwoods 10's. (KFC-W2513PS) 300 rms 4 ohms each. Frequency response: 39-300 Hz Sensitivity: 82 dB. They are wired at wired at 1.33ohms
    My amp is a planet audio bb2400.1 (2400 rms x 1)
    My questions..
    Input sensitivity: 100m-2v or 2v-8v? (Is that dependent on power of my rca outputs on my head unit?)
    Amp Bridge mode: Do I select Master or Slave? I dont get it, I am going to use a bass knob so I insert that end into the remote level control correct? What is the data link for?
    Input level?
    sub filter?
    Low pass?
    Phase selector?
    Sorry I bought the amp used and it didnt come with an instruction book I could read.
    and Bass boost im assuming that is done to the level of comfort? Correct me if Im wrong.
    Thanks in advance!
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    37
    2,834
    1 Post(s)
    864 Post(s)
    Re: Please help me with my amplifier settings, Thank you!
    Ok first set it to master that link and slave master is to link two amps, if using HU rca's set the input level to2v-8v input level is your gain set the sub filter to about half way leave phase at 0 set the low past just a hair above minimum since it bottoms out at 50hz and leave the boost at minimum and you should be good to go, also look in the amp section on here ans see how to set your gains correctly!
    electrical: Optima yellow top X 2 big 3 in monster OFC 1/0g high output alt by maniac electrics
    HU: JVC AVX-77 touch screen
    Front stage: RE XXX 6.5" comps
    front stage amp: Rockford T600.2
    subs: 1 Sundown ZV4 12"
    sub amp: Rockford T2500.1BDCP
    Enclosure: ported (by JayDubb757 )
    chillin's Avatar
    chillin is offline CarAudio.com Elite
    Jan 2007
    Whistler, Canada
    1,802
    201 Post(s)
    What head unit are you using? You will most likely want to use 2-8 for input. The sub filter is useful if your box is ported. It prevents the sub from bottoming out below tuning frequency, aka subsonic filter. Low pass is how high you want the sub to play. If your mids play down to 80, you would want the low pass to be set a bit below that. The phase selector is the same as putting the negative cable in the positive and positive cable in the negative. It makes the speaker go in when it should go out and vice versa. This is useful sometimes to help the sub blend better with the front speakers.
    Children are the future… today belongs to me!
  1. Please help me with my new set up.
    By Scotty_Dogger in forum General Discussion
    Last Post: 12-11-2008, 06:12 PM
  2. Please Help Me With My ' CUSTOM ' Stereo Project!
    By TXSTYLE in forum General Discussion
    Last Post: 03-07-2003, 01:55 AM
  3. PLEASE HELP ME WITH My ROCKFord system
    By rockford666 in forum Wiring, Electrical and Installation Help
    Last Post: 10-04-2002, 03:58 PM
  4. please help me with my set up
    By CaddyLacGrills in forum Wiring, Electrical and Installation Help
    Last Post: 03-30-2002, 09:17 AM
  5. Replies: 27
    Last Post: 03-20-2002, 12:29 AM
