Results 1 to 2 of 2
Reload Thread: 200 amp alt overkill on a civic w/ 1500 watts?
    pudgewack's Avatar
    pudgewack is offline Junior Member
    Feb 2004
    KCMO
    38
    20
    I have a civic that has a 75 amp alt stock. I am going to be installing 2 amps that will have that will produce roughly 1500 watts (JL 1000/1 and JL 450/4). My stock alt will not be able to make the power that I am needing. I can not decide about the size of alt that I should upgrade to. Originally I was going to get a 150 amp alt. Then using the logic that bigger is always better....I considered a 200 amp alt.
    Is 200 amps overkill? Any negative effects on the electrical system by giving it that much more power?
    Thanks,
    Matt
    randomco's Avatar
    randomco is offline Satellite Extrordinaire
    Jan 2004
    San Diego, CA
    496
    Re: 200 amp alt overkill on a civic w/ 1500 watts?
    people have a misconception about h/o alternators. No matter what amperage the alternator is, it still is gonna put out 12 - 14.4 volts. lets just call the amperage "storage". it stores power, it is not going to send all your electrical components more than they use. the componets are only gonna use as much power as they need. Same thing with your amplifier. It is only gonna take as much power as it needs. the alternator is not gonna send the amp or anything else in the car more power than it needs. so to answer your question, no, it will not negativaley effect your cars electrical.
  1. *amplifiers/power ratings*
    By dbhittin in forum Amplifiers
    Last Post: 06-30-2008, 11:33 PM
  2. Terminology - Please contribute
    By frozenfire89 in forum General Discussion
    Last Post: 02-12-2004, 10:06 PM
  3. will alt power these?
    By goodrich in forum Amplifiers
    Last Post: 12-31-2003, 12:31 AM
  4. Power Acoustik
    By anaranchi in forum Amplifiers
    Last Post: 08-17-2003, 11:58 PM
