+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 36
Reload Thread: I immediately blew my new subs.
  1. #16
    therockdrummer's Avatar
    therockdrummer is offline Junior Member
    Jul 2012
    Scottsdale, AZ
    Re: I immediately blew my new subs.
    Quote Originally Posted by xSPLoder808 View Post
    explain in detail how you wired up each sub
    Put the jumper in the middle +/- posts. in each sub. Wired the set of outside +/- to the terminal inside the box. Connect one terminal to the other behind box. Run one set to the mono amp. Same setup as the D4's, just now a 2ohm load.
  2. #17
    skylineTT's Avatar
    skylineTT is offline bass=sekz
    Jun 2007
    Dallas/Raiderland
    4,003
    5 Post(s)
    Quote Originally Posted by SourDeez View Post
    You must have accidently wired it to half ohm, because theres no way that two type R's will immediately blow off 1200rms and minimum gain. I had two type R's on 2400rms+ for like 2 years
    You don't got to lie craig!!
    Refs: Dipitydoo, appollyon, bad95gt, revrider1, jwh1598, ampjunkielikeme, deathpenalty18, ssackett, snoopysnooper, corey0928, SPLAudio, Clifff150, CL1CKCLACK, ShawnT, West + more
  3. #18
    skylineTT's Avatar
    Jun 2007
    Dallas/Raiderland
    4,003
    5 Post(s)
    Quote Originally Posted by therockdrummer View Post
    yeah, that sounds correct, unless you just accidentally reversed the polarity at the box terminal. are you absolutely sure they are blown?
  4. #19
    May 2012
    The Roc, NY
    1,303
    6 Post(s)
    stick a 9v battery to the VC's. It wont hurt it. Put the + of the battery to the + VC and vice versa with the -. If the sub is blown it won't move. If it is still good, it will push the cone up and hold there till you take the battery off.
    95 Ghetto Bangin xSPLoder Limited
    BOYCOTT SKAR AUDIO!
    2012 TNESPL R2 WORLD CHAMPION
    TNESPL R2 ALL TIME RANKINGS RECORD HOLDER
    TEAM
    TEAM 808
    www.youtube.com/Team808NY
  5. #20
    SourDeez's Avatar
    SourDeez is offline CarAudio.com Veteran
    Apr 2007
    Fuqy u
    4,134
    62 Post(s)
    Quote Originally Posted by skylineTT View Post
    who da fuq is craig. i'm old greg
    Headunit - Stock cassette player - Pioneer P9400
    Front Stage - Pyle 8 inch subs (1000 watt peak!!) - Polk DB6.5 (about to be CDT 6.5s)
    Rear stage - Deleted (stolen) - Deleted
    Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) - Two SA12's built by Corey
    Sub amp - Pyle 8000w peak!! (spl edition) - AQ2200
    Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable - Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
  6. #21
    Jul 2012
    Scottsdale, AZ
    both times, the cones stayed fully extended, and smoke came out of the vents. I assumed that meant they are blown.
    I just put a battery to them and they do jump and thud a small amount. What does this mean?
  7. #22
    May 2012
    The Roc, NY
    1,303
    6 Post(s)
    That means they are still good like I said before.
    BOYCOTT SKAR AUDIO!
    TEAM
    TEAM 808
  8. #23
    Jul 2012
    San Diego, CA
    22
    70
    You paid $700 to 2 pairs of mediocre subs?! Holy crap.... and you spent over a grand on that set-up? That was your first problem.
    Secondly, it doesn't quite sound like you know what you're doing, so who knows what the issue could be. Amp could be bad sending DC current to the sub. Subs could be wired wrong. Gain set wrong. Bass boost and loudness being used?
    Also, do like xsploder said and test the sub with a battery.
    Quote Originally Posted by Imtjnotu View Post
    I put AudioTechnix sound deadener on my 21" Kicker L7 and it puts out 10 more deebeez now!
  9. #24
    May 2012
    The Roc, NY
    1,303
    6 Post(s)
    If they were blown, they would not of even moved at all and would be stiff enough for you to stand on without moving pretty much.
    BOYCOTT SKAR AUDIO!
    TEAM
    TEAM 808
  10. #25
    treesive's Avatar
    treesive is offline Senior VIP Member
    Mar 2011
    batesville, IN
    202
    It is looking like when you fried the first set you may have fried something in the amp. Next time do some more research on how to properly set and connect everything before burning up some more of your cash.
    The Ride: 1996 Chevy Tahoe 4-Door
    The Setup: Headunit: Pioneer DEH-P80PRS
    Front Stage: Pioneer 720PRS Comps
    Rear Cargo: JBL P963's
    Subwoofers: Audiopulse LMS Ultra 15"
    Sub Amp: Soon to be PG Elite.1 (HERE!!)
    High's Amps: Soon to be PG Elite.4 (HERE!!)
  11. #26
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    32
    2,816
    11 Post(s)
    sounds like the amp is shot and unloading on the sub when it powers up, even if the subs still work there not worth crap now that they rolled smoke!
  12. #27
    Canaan's Avatar
    Canaan is offline Beatin' the block down
    Mar 2006
    Monroe, Louisiana
    1,432
    3 Post(s)
    If the subs fully extended and smoked....its likely your amp is damaged.
    Disconnect your subs from the amp and stick a DMM set to DC-voltage on the amps speaker terminals.
    If you are getting DC voltage, your amp is fried.
    Canaan White
    -'04 Avalanche, Eclipse 7200MkII, DD C4a, DD AT28 and AW6.5 (German comps) active,
    -2 DD3515E 6th order, 2 DD M2a @ 1.5ohm, 150+ @ 38hz
    Team South
    Desiard St. Pawn and Car Audio
    DD, Arc, Sundown, HAT and dB Drive Dealer
  13. #28
    May 2012
    The Roc, NY
    1,303
    6 Post(s)
    wouldn't hurt to hook em up to a home audio receiver and free air test them for any coil damage. Might of got lucky and caught it quick enough to still run them
    BOYCOTT SKAR AUDIO!
    TEAM
    TEAM 808
  14. #29
    Jul 2012
    Scottsdale, AZ
    Quote Originally Posted by I<3AudioTechnix View Post
    I think slightly over a grand was more than fair for the results I was seeking. Also, just because I acted like a teenager on the gain knob, doesn't mean I 'don't know what I'm doing'. There is no bass boost, no loudness. See above for the results of the battery test.
    We will see.
    Quote Originally Posted by treesive View Post
    I definitely will. I have ordered the SMD DD1, should be here on Friday. But until then, I need to make sure no more brand new subs explode upon plugging them in. What exactly could have been damaged in the amp? The PDX has a LED that is supposed to indicate any issues the amp is having, but it is lighting up blue as it should. ?
    Quote Originally Posted by goingdef View Post
    explain!
  15. #30
    May 2012
    The Roc, NY
    1,303
    6 Post(s)
    I dk, that's a pretty n00b move man. Not to mention spending over a G on Alpine stuff. No offense, just kinda n00bish
    BOYCOTT SKAR AUDIO!
    TEAM
    TEAM 808
  16. Likes southernboom88, I<3AudioTechnix liked this post
+ Reply to Thread
  1. blew my sisters sub and need a new one
    By Wkbdkid in forum Subwoofers
    Last Post: 07-06-2006, 01:18 PM
  2. About my new subs
    By GTGchevy in forum Wiring, Electrical and Installation Help
    Last Post: 10-02-2002, 08:35 PM
  3. Amp to pout my new sub
    By Corsica in forum Amplifiers
    Last Post: 06-23-2002, 01:22 AM
  4. Can't hear my new sub
    By maylar in forum Subwoofers
    Last Post: 03-12-2002, 01:16 PM
Tags for this Thread
