Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
Re: Subwoofer and Amplifier Help!
Originally Posted by
quackhead
I would suggest buying a matching MTX 10 to the one you have, or going with 2 SVC 4 ohms wired to 4ohms on that amp. Just because Kicker says they will work in .8 cubes does not mean they will sound very good with any decent power, I have never heard one sound good sealed at all. you start throwing power to them in that small a space sealed, and you might burn a coil from too much compression, even worse if you clip them trying to get more volume.....or too big a box with too much power will make them exceed xmax and bottom themselves.
I am not returning these subwoofers. I really don't think I have to buy a new box, because they sounded great @ 400RMS with my old amp. It's just this new amp that has changed so much.
Turn your freq. up, if you are at 45 make it closer to 80-85
I would pull the 10 on the passenger side and block the hole if it were possible and then install a 4" precision port into the end of the box on the passenger side firing into the passenger side wall. Wire the other 10 to 4 ohms @ 450 watts and have a good day...IMO
"Bailout: Taking a trillion dollars from the people and giving it to the banks so the banks can loan it back to the people, at interest!"
..or a 3" port, or two 2"...whatever will work
Try finding a local shop or someone knowledgeable tuning amps in your area, A good tune might fix your problem.
2008 G8 LC6i Kenwood 6.5's upfront, Morels in the rear. Alpine PDX-F4, 2x BA-SPG555 sealed with JBL 14001
2004 Pontiac Grand Prix GT2
Head unit - eclipse CD5000
Front Components - Boston Z6's Rear "fill"- Boston SR95
Front&Rear Amp - Boston GT24
Sub -2x Boston SPG-555 @ 34hz
Sub amp -BA GT28
ect - 12 farad stinger cap,0 gauge stinger wiring, stinger 1500 battery, 200a alt
refs: keifersracing
quackhead
I would suggest buying a matching MTX 10 to the one you have, or going with 2 DVC 4 ohms wired to 4ohms on that amp. Just because Kicker says they will work in .8 cubes does not mean they will sound very good with any decent power, I have never heard one sound good sealed at all. you start throwing power to them in that small a space sealed, and you might burn a coil from too much compression, even worse if you clip them trying to get more volume.....or too big a box with too much power will make them exceed xmax and bottom themselves.
So I went back outside and messed with the settings after talking to someone from Kicker, and I'm impressed. I had the voltage level turn to ~2.5 to match my radio, but when I turned it down to the minimum (0.2v), it sounded amazing. It was shaking my rear view just like I wanted it to. I just don't know how safe that is.
...I am redoing my thoughts here, you turned it up to .2..all the way clockwize?
Yeah I turned it all the way to 0.2v which Hifonics said was extremely bad so I turned it back up to 2.5v.
xxbobbyfinxx
I figured Kicker was just trying to sell you some more subs. Seriously though, Look into the DC XL 10, or the SSA SD 10, and compare sub depths to the ones you have. A ported box can be built to use a single 10 mounted a little lower than yours, and done correctly, would provide much more output gains than just trying to add power to two sealed in that airspace. One 10 done right and powered with 1000 - 1500 watts will blow you away.
quackhead
If only I had the money or time to do that kind of install. I just wanted some good bass and have it hidden. You can't see anything now and it's perfect.
By Trepkos in forum Subwoofers
Last Post: 07-22-2007, 11:25 PM
By chartman18 in forum Amplifiers
Last Post: 11-08-2006, 01:09 PM
By 996twint in forum Subwoofers
Last Post: 08-24-2002, 02:15 PM
Tags for this Thread
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
