Results 1 to 6 of 6
Reload Thread: From 4 Guage to 8 Guage Power Wire
    sungwei's Avatar
    sungwei is offline Senior VIP Member
    Mar 2004
    lkj
    264
    My wiring kit didn't come with a long enough 4 gauge power wire so my friend and I put it in a 4 gauge to 8 gauge distribution block and used the 8 gauge wire to hook up to amp. What difference would it make if the whole power wire was 4 guage? Any foreseeable problems?
    svtlightning93's Avatar
    svtlightning93 is offline Junior Member
    Dec 2003
    denham springs, La
    27
    Re: From 4 Guage to 8 Guage Power Wire
    Depends on what size amp you are running. The longer the distance the bigger the wire needs to be. If your running an amp at 350 watts or less , 8 gauge should be fine. Most people run 4 gauge to a distribution block and then smaller to there amp, in case they add another amp they can just run another small wire to the block.
    sungwei's Avatar
    Mar 2004
    lkj
    264
    It'll be pushing around 200-300 watts RMS but I doubt I'll even be using that much power. I did exactly what you described. The bulk of the length is 4 gauge. About 14 feet 4 gauge. Then about 3 feet 8 guage.
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,013
    1 Post(s)
    264 Post(s)
    the 14' of 4 ga is about 3x as resistive as the 8 ga.
    You're fine.
    Actually - with that amount of power 8 ga all the way would get the job done. Probably even 10.
    cdr's Avatar
    cdr
    cdr is offline Member
    Dec 2003
    AZ
    31
    136
    IMO running 4GA just leaves so many doors open for you down the road so its a good think even if you arent using all that it can provide
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    30
    3,509
    Yea i am with cdr. Always run bigger wire than you need. Because the majority of people run the min for their current system and decide to go bigger and better. Therefore having to run bigger wire to handle their new system. It definately leaves doors open. Never know when you might need it.
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
  1. should i run EVERYTHING away from the power wire?....
    By allyourblood in forum General Discussion
    Last Post: 02-27-2004, 06:59 PM
  2. switch power wire?
    By dizzlenizzle in forum Wiring, Electrical and Installation Help
    Last Post: 01-04-2004, 08:23 PM
  3. Guage power wire
    By syntac in forum Wiring, Electrical and Installation Help
    Last Post: 10-31-2003, 03:55 PM
  4. help NO POWER PLEASE! URGENT
    By Alpine4life in forum General Discussion
    Last Post: 10-08-2003, 04:17 PM
