Results 1 to 3 of 3
Reload Thread: Please Help - Subwoofer Ohms
    U-H.Com's Avatar
    U-H.Com is offline Member
    Oct 2002
    Grimsby, Ontario
    38
    61
    Guys do amps put out less power the higher your load is? Like say if I was to use a amplifier such as the R804 which is 400x2 @ 4ohms, and I hook up two DVC4's to it so that would be 8ohm load per channel, would I still get the full amount of power? I ask because I want the single vc models, but they are not in stock...only the dual 4's...any help would be appreciated...i thought that anything over 4 didn't matter, but i might be wrong...
    homer3304's Avatar
    homer3304 is offline Member
    Mar 2004
    midwest
    45
    61
    Re: Please Help - Subwoofer Ohms
    every time you double your ohm load, you roughly half your power. So a 500 watt amp at 4 ohms would put out roughly 250 watts at 8 ohms.
    forbidden's Avatar
    forbidden is offline CarAudio.com Elite
    Jan 2004
    CFB Comox, BC, Canada
    49
    1,127
    And what exact amp is making 400w x 2 @ 4 ohms, I would love to see it. If your amp is bridgeable to a 4 ohm mono load, but the dvc 4 ohm subs and wire them in a series / parallel circuit. This will be a stable 4 ohm mono combined load that is safe for the amp to run. A 400w x 2 amp, priceless.....
    Yeah, whatever
  1. 1000+ Watt Amplifiers
    By Gauntlet in forum Amplifiers
    Last Post: 04-16-2006, 01:07 AM
  2. 2 ohms 4 ohms 8 ohms help!!!!!!!
    By pj2003 in forum Wiring, Electrical and Installation Help
    Last Post: 01-03-2004, 08:40 PM
  3. 1000+ Watt amplifiers
    Last Post: 12-13-2003, 11:36 PM
  4. stupid q about ohms
    By mr_f4ke in forum Subwoofers
    Last Post: 10-24-2003, 11:15 AM
