Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
99' Toyota Solara Speaker Problems
On my brother 99' Toyota Solara the right front door speaker has been kicking on and off at random. We took out the speaker, and messed with the harness and that seemed fine. Whenever the speaker kicked off, we could push the cone of the speaker in and out and it would kick in again. Then shut off on its own.
All the wires looks intact, but do you think it could be something internally on the speaker?
Re: 99' Toyota Solara Speaker Problems
i had a subwoofer do this one time and what had happend is that the voice coil had burned but not completely i would take it out and sniff it and if it smells burt try another one!
^ That might be possible, thanks for your input!
Any other ideas?
connect known working speaker to factory wires see if problem persists. Most likely to be bad speaker from what you describe.
By saltyjesus in forum Subwoofers
Last Post: 10-07-2002, 10:44 AM
By namster44 in forum Wiring, Electrical and Installation Help
Last Post: 08-12-2002, 12:32 AM
By cameroturbo in forum Wiring, Electrical and Installation Help
Last Post: 07-10-2002, 02:22 PM
By JONNY_MTX in forum Wiring, Electrical and Installation Help
Last Post: 05-31-2002, 07:28 AM
By millinivation in forum Subwoofers
Last Post: 04-10-2002, 10:28 PM
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
