pretty much this,you can get plastic plates from crutch field
pioneer avhp 4100 dvd, 2 dc lvl 4 10's custom built by Thor's hammer , ab vfl 4480
ab vfl 150.4 ,2 pc 2150 ,
cdt 6.5 es 61 im mids,cdt es 010 tweets with es 200 us x overs stinger hpm o gauge wires
NOR CAL DB DRAG JUDGE
http://www.dcsoundlab.com
I'm getting the new pioneer touchscreen double din. In my Camry I had 4 jbl 6x9s and they sounded pretty good. Is converting to 6.5 a difficult process? And why do they sound better them other size
its not hard ,just get the adapters .the reason they sound better is the preformance of the round speaker its self. some of the other more technical guys on the forum will prolly chime in on this
what we hear as music is actually the movement of air that vibrates your ear drum. What causes this vibration is the movement of the speaker cone causing compression and rarification(sp?) in the air around it. Round cones give a relatively equal movement of air from all points of the cone. Because 6x9's have the oval shape, the outside edges that have less surface area move smaller amounts of air than the inner area with larger surface area. The difference in the sound waves that project from the different areas cause acoustical issues.
Makes perfect sense, I'll look into those thanks
I have held off on subwoofer installation and want to focus on a nice speaker setup for now. If I am going with components what are some good brands? I have no problem buying an amp if that will help. I listen to mostly country and rap.
Hybrid Audio Imagine are a great $200 convertible component set that sound good with litte power. Very efficient. Would make a nice drop-in replacement. 6.5 in front doors, tweeters in new locations using supplied mounting hardware, and 6x9 in rear for more bass response.
If you plan on adding a sub later, you can put 6.5 in rear.
I61–2 front
I69-2 rear
Or you could just drop I69-2 in front and rear. But the 6.5's have smoother midrange response.
have you been helped by me? i'd love to know. shoot me a PM.
My 2001 Accord build log:
http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
Can I help you? valencebandacoustics@gmail.com
Want to learn about car audio electronics?
http://www.bcae1.com
Like I said before I am a fan of Hertz so I will be recomending the Hertz ESK or HSK component sets. While these will sound best with an amplifier, the ESK are pretty efficient and have worked well for people just upgrading the stock speakers. They are however not convertable components, the tweeter and midbass will need to be seperatly mounted
Thanks ill take a look at those. So the major companies that are known for subs don't really make the best speakers? Just curious because the shop I went to had mostly jl kicker alpine jbl etc speakers.
It really depends on how high end you want to go. Nicer Alpine, JBL, and JL aren't bad, but the brands I have seen recomended to you so far are superior IMO
imo the whole round oval debate is getting old. i've heard plenty of awesome sounding 6x9's. for example the ID XS69. that combo in itself sounds beautiful pair the mids up with horns it's even better.
Pioneer Carrozzeria DEH P01
Tru SB6
Silver Flute W17RC38-08 6-1/2" Wool Cone
Tru Steel S25
ES Full body horns soon to come
2x JBL W12GTI
Im looking for mostly sound quality and a real clean sound btw
do you have a price range?
Tru SB6
Tru Steel S25
2x JBL W12GTI
Price doesn't really matter as long the speakers are worth the money but if there are higher quality speakers out there that arent the most expensive thats even better.
what type of sound are you looking to achieve?
Tru SB6
Tru Steel S25
2x JBL W12GTI
Bookmarks
