Results 1 to 5 of 5
Reload Thread: '02 Yukon Wiring Issue
    fasfocus00's Avatar
    fasfocus00 is offline doITdaWHITEwayORdoITtwice
    Jun 2007
    New Orleans, LA
    5,618
    3 Post(s)
    459 Post(s)
    tried searching but nothing. I am installing a 5 channel amp and a new head unit for someone. everything is hooked up and I have no sound through the door speakers. i tried to see if anything is going to the door speakers and nothing. I wired everything according to the harness and nothing is going to the speakers. I used speed wire to connect the amp speaker out puts to the back of the speaker harness at the radio. somehow the harness speaker leads do not go to the speakers in the doors. any help?
    Here is my feedback Thread: http://www.caraudio.com/forum/showth...ght=fasfocus00
    "If you ain't cheatin', You ain't trying"
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    141 Post(s)
    1 Thread(s)
    6015 Post(s)
    Re: '02 Yukon Wiring Issue
    has to be an factory amp then
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    fasfocus00's Avatar
    Jun 2007
    New Orleans, LA
    5,618
    3 Post(s)
    459 Post(s)
    Quote Originally Posted by mylows10 View Post
    when I plug the factory headunit up, just the one plug that the harness connects to I get sound through the speakers. I tried popping the speaker (i know you're not suppose to do that but i'm desperate) and no speakers pop. i there a quick way to by pass the amp if that's what I need to do?
    fasfocus00's Avatar
    Jun 2007
    New Orleans, LA
    5,618
    3 Post(s)
    459 Post(s)
    it has 2 factory harnesses but I only have one harness, the one harness I have plugs up fine and has all the wires for the speakers, power, and ground but the speaker wires don't connect to the speaker. were can I tap into the speakers?
    fasfocus00's Avatar
    Jun 2007
    New Orleans, LA
    5,618
    3 Post(s)
    459 Post(s)
    got it work but factory sub still plays and sounds like chit. the fix is connecting the solid blue wire on the harness to the HU remote turn on. now i need to figure out how to remove the panel that houses the factory sub. don't reply w/ some BS about the panel just snaps off, no it doesn't b/c there are atleast 3 screws I see and that little black knob on the back with a nut on the back side inside the panel that nothing can get to and turn.
  1. 02 Altima wiring issues
    By jbake2166 in forum General Discussion
    Last Post: 08-03-2011, 06:45 PM
  2. speaker wire issue
    By no_vendetas in forum Speakers
    Last Post: 02-23-2004, 11:07 AM
  3. wiring issue
    By JeffG in forum Wiring, Electrical and Installation Help
    Last Post: 12-14-2003, 07:59 PM
  4. Odd remote wire issue.
    By DiB in forum Wiring, Electrical and Installation Help
    Last Post: 08-11-2003, 01:39 PM
  5. HELP! '02 yukon head unit install...no sound!
    By gotdub4s in forum Wiring, Electrical and Installation Help
    Last Post: 02-27-2003, 01:58 PM
