Results 1 to 3 of 3
Reload Thread: Headunit pop with turning on and off
    SMFJ's Avatar
    SMFJ is offline Senior VIP Member
    Nov 2010
    Albany, Georgia, United States
    308
    69 Post(s)
    Icon32 Headunit pop with turning on and off
    I've read a few posts about this speaker already but have found no solution.
    Background:
    A while back I hot swapped my rcas while the deck was playing (dumb move in retrospect) and I started getting a lot of engine noise in my RCAs. Long story short I'm guessing I blowed the pioneer pico fuse or whatever it's called. I found a stickie on here or another forum about how to ground pioneer RCAs. Worked like a charm signal sounded better than new.
    Then came pop thumb that been beating and my mids. I know it has to be a head unit problem because I can only duplicated the issue when the radios RCAs are present.
    Has anyone ever successfully fixed this issue without sending off or replacing the HU.
    1x Custom PSi built 3HP with Signature TC Style Basket
    1x Audiopipe APSM-1500(Soon to be 2 or 2 APSM-2000s)
    4 Pyramid TW47 Supertweeters
    4 Parts-Express Buyout 6" Midranges, 4 Parts Express Peavey 8" Guitar Speakers
    Crescendo C1100.4
    Kenwood KDC-X996
    FEEDBACK: http://www.caraudio.com/forums/itrader.php?u=1002745
    gleep52's Avatar
    gleep52 is offline Junior Member
    Apr 2012
    Colona, IL
    Re: Headunit pop with turning on and off
    Do you have all your speakers going through amps? Or do you run your mids off the headunit. Try disconnecting your remote turn on wire - does the problem go away? I've replaced a headunit for this in the past - but in other scenarios I've also solved the problem by adequately grounding both the head unit and the amps. Sometimes the ground wire in a factory harness isn't big enough for after market head units... Ground it to the frame with the proper gauge wiring. I've also had a bad ground cause the subs to pop on me before... use some steel wool and get a real clean connection to the frame... Hopefully this helps!
    All_Logix's Avatar
    All_Logix is offline Formerly CivicGTi
    Dec 2010
    Texas
    694
    49 Post(s)
    Has the pop always been there, and what kind of vehicle do you have?
  1. Headunit turns on and off while driving
    By JML0124 in forum Wiring, Electrical and Installation Help
    Last Post: 11-29-2011, 11:37 PM
  2. Headunit randomly turns on and off ?
    By Jakey253 in forum General Discussion
    Last Post: 04-19-2010, 01:54 AM
  3. protection light keeps turning on and off
    By pontiac_rayzer in forum Wiring, Electrical and Installation Help
    Last Post: 11-30-2005, 12:49 AM
  4. Amp turns on and off
    By WiNnErPL in forum Amplifiers
    Last Post: 11-01-2004, 11:20 AM
  5. Front speakers turn on and off need help!!!
    By EdrikLongtail in forum General Discussion
    Last Post: 08-08-2004, 11:50 AM
Tags for this Thread
