Results 1 to 15 of 15
Reload Thread: lights dimming and loss of RPM's at idle ...... need suggestions please help
    Big Rich's Avatar
    Big Rich is offline Member
    Jan 2012
    Brooklyn NY
    86
    28 Post(s)
    i drive a 2000 buick lesabre i have done the big 3 all other electrical like alternator and battery is stock
    theres a good amount of dimming when my car is stopped at a light, ive also noticed that when my car is idling and rolling when i take my foot off the brake the RPM's drop and my car kinda stops moving a little bit to the beat of the music/bass
    will adding another battery help this ? i plan on getting a stinger 5 farad capacitor (i know they do nothing but i want one anyway). and i want to add on another battery, im not sure which is a good brand or what to get heres my amp specs
    the amp is currently wired at 1 ohm to a single skar 12 wired at 2ohm. so im assuming its running at the full 1600 watts
    cadence daytona DCA1600
    4 ohm RMS Power: 1 x 50 Watts
    2 ohm RMS Power: 1 x 1000 Watts
    1 Ohm RMS Power: 1 x 1600 Watts
    2 Amps Bridged: 1 x 3200 Watts
    Frequency Response: 10Hz - 500Hz
    S/N Ratio: >100 db
    Damping Factor: >500 @ 100Hz
    Minimum THD: <0.03%
    Low Pass Crossover: 35Hz - 250Hz
    Subsonic High Pass Filter: 10Hz - 50Hz
    Bass Boost Equalization: 0-18db @ 45Hz
    Lucite Encapsulated Large 2 and 4 Gauge Connection Terminals
    Dash Board Bass Remote
    Input Voltage: 200 mV - 6 Volts
    Dual-Amp Bridging for Double the Power @ 2 Ohms
    Master/Slave Control
    Adjustable Phase Control
    RCA Line-In/Line-Out Jacks
    24db Crossover Roll Off
    Dimensions: 13" x 9.5" x 3.5"
    Phoenix Risen's Avatar
    Phoenix Risen is offline OG.... Original Ginger
    Jun 2010
    Dayton/Springfield, Ohio
    4,064
    350 Post(s)
    Re: lights dimming and loss of RPM's at idle ...... need suggestions please help
    is your sub wired at 2 or is a d2?
    R.I.P. 2008 Hyundai Tiburon GS
    2005 Subaru Baja turbo, build in planing stages.
    Big Rich's Avatar
    Jan 2012
    Brooklyn NY
    86
    28 Post(s)
    It's a d2 wired parallel
    09civic's Avatar
    09civic is offline CarAudio.com Veteran
    Dec 2010
    Melbourne, FL
    6,832
    1229 Post(s)
    What size is your alt? Make sure your grounds are secure and actually a good ground. Make sure everything is tight.
    Dr. Slam's Avatar
    Dr. Slam is offline Slamming hoes n trunks...
    Nov 2010
    Chicago Heights, IL
    639
    120 Post(s)
    Sounds like your alternator is failing. I got the same car and when my alt went bad, my voltage / rpms would surge at idle. Then finally my alt when out.
    Head Unit: Alpine Ixa-W404
    Front Stage: Alpine Type X 5.25 Component Speakers
    Front Stage Amp: JL 300v2.2
    Rear Stage: 4 Infinity Kappa Perfect 6x9s
    Rear Stage Amp: Stetsom 600.4
    Subs: 2 Sundown Nightshade V.2 15s Spl Coil Upgrades
    Enclosure: Building 6^3 ft Tuned to 32 hz
    Sub Amps: 2 Sundown 3000ds
    Batts: kinetik 1400, 2400, Looking for 2 more 2400 equivalents or better
    250a Mechman HO Alt
    Big Rich's Avatar
    Jan 2012
    Brooklyn NY
    86
    28 Post(s)
    It's a 105 amp alt. have checked grounds when I installed the system last week but will recheck it when I get home.
    Jun 2010
    4,064
    350 Post(s)
    its either that the car just wont handle the load being put on it or its going south.
    Big Rich's Avatar
    Jan 2012
    Brooklyn NY
    86
    28 Post(s)
    Say I just sold the cadence amp and got something smaller in the 600-800 watt range would that make a difference ?
  9. #9
    Jun 2010
    4,064
    350 Post(s)
    only way it will make a difference is if it is actually the amp causing it.
  10. #10
    J31Rob's Avatar
    J31Rob is offline CarTune Netwerk
    Nov 2006
    Indiana
    11,243
    397 Post(s)
    Improve your electrical system or you'll always have issues, that's the easy answer. Best one IMO too.
    the FUNK / facebook.com/The.Funk.765
    CarTune Netwerk / facebook.com/cartune.netwerk0
    Alpine / Sundown Audio / Sound Solutions Audio
    Audio Technix / CT Sounds / Execution Audio
  11. Likes Phoenix Risen liked this post
  12. #11
    09civic's Avatar
    Dec 2010
    Melbourne, FL
    6,832
    1229 Post(s)
    Whether the amp does 1k or 8k, if you set your gains correctly, it shouldn't matter.
  13. #12
    Big Rich's Avatar
    Jan 2012
    Brooklyn NY
    86
    28 Post(s)
    The sub hits very hard and neither the amp or sub cone get warm at all. I'm not sure if it's the amp honestly. I just thought that since it was 1600 watts that it pulled a lot of power from the battery.
    This is my first install so I just don't know where to start looking. The last thing I want to do is screw up the car
  14. #13
    MECHMAN's Avatar
    MECHMAN is offline Senior VIP Member
    Jul 2008
    Knoxville, TN
    362
    1 Post(s)
    29 Post(s)
    Your amp consumes about the same power that your factory alternator will produce at peak. Your vehicle will pull most of what your alternator can produce in it's normal operating range, generally up to 80a. That's not leaving much to power your system.
    Then factor in the alternator is only putting out about 50-60a at idle and you will not have nearly enough amperage available to maintain your batteries.
    For your system to function properly with that amp I would recommend that you install one good battery like an XS Power under the hood, use a high output alternator with good low-speed charging and wire everything with quality cable.
    CCA cable is OK when used properly.
    Avoid cheap batteries.
    Avoid cheap alternators that claim big power, they don't generally perform at low engine speeds.
    Builder of alternators.
    www.mechman.com
    865-522-6166
    1-800-MECHMAN
  15. #14
    Big Rich's Avatar
    Jan 2012
    Brooklyn NY
    86
    28 Post(s)
    im going to try lowering my gains a bit in case that could be part of it. after that im going to just try a battery than after that il go with switching out the alternator. what is a good reliable one ??
    what are the minimum amps the battery should be ???
  16. #15
    dot8905's Avatar
    dot8905 is offline Member
    Jun 2010
    dorchester, ma
    36
    had the same problem with my park avenue a few years back threw a kinetic 1800 and ran great i was running a saz-1000d at the time. I still have the same battery in another vehicle but no stereo anymore
