Results 1 to 4 of 4
Reload Thread: Best way to fill in parts of dash bezel?
    jpinusmc's Avatar
    jpinusmc is offline Junior Member
    Aug 2009
    Lebanon, Or
    Not sure if this should be here or in the interior part, but since I am doing an install, I'll put it here.
    Looking to fit a double-din deck into this single din bezel. I will be cutting upwards into the section of holes right below the heater vents. My questions are:
    What is the best material to fill in the holes and make the bezel complete?
    Should I fill in the holes first and then make the cutout for the deck or should I make the cutout and then fill in whats left?
    Thank you!
    frogcase2002's Avatar
    frogcase2002 is offline Senior VIP Member
    Dec 2011
    hamilton, ohio
    476
    23 Post(s)
    Re: Best way to fill in parts of dash bezel?
    i would cut out the exact size you need then cover that whole piece and fiberglass it, sand, paint, think that would look the best
  3. Thanks jpinusmc thanked for this post
  4. #3
    CivicGti's Avatar
    CivicGti is offline CarAudio.com Elite
    Dec 2010
    Texas
    682
    1 Post(s)
    Also I would recommend sanding the plastic a a ouch to give the resin some grooves to adhere to. As for painting your best bet is to take the dash into a local paint shop and see if they can help you match it.
  5. Thanks jpinusmc thanked for this post
  6. #4
    Dec 2011
    hamilton, ohio
    476
    23 Post(s)
    Quote Originally Posted by CivicGti View Post
    yes
