Results 1 to 6 of 6
Reload Thread: 4 Channel Amp Wiring
    Xen's Avatar
    Xen
    Xen is offline Junior Member
    Mar 2012
    Tampa, FL
    1 Post(s)
    Icon32 4 Channel Amp Wiring
    Now before I get into detail I just want to point out that I have seen and heard of the way of how to wire a 4 channel amp. I have even seen the howto from the Crutchfield site which is also btw more than 5 years old.
    Now I have a 4 Channel amp, or had the amp installed in my Scion xB, which I had to remove because I ended up get an Eclipse. When Best Buy had wired my amp in my Scion, they didn't run the wires from the door speakers to my amp, instead they kept the factory wiring and ran the speaker wire from the amp and butt connected the amps speaker wire to the after market wiring harness. The just made sure that the wire harnesses speaker wire was no connected to the HU.
    The only thing that was connected to the HU, was Ground, ACC, Illumination, Dimmer, Antenna, Remote(From Amp) and RCA(From Amp) for Sub Inputs. I was wondering if it was ok to continue to wire this way and avoid the frustration of running wires from the door and reduce clutter?
    ht tp:/ /tiny .cc/IoWe2b
    remove spaces to see image of example.
    Xen's Avatar
    Xen
    Mar 2012
    Tampa, FL
    1 Post(s)
    Re: 4 Channel Amp Wiring
    Wtb a reply
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,432
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    yes it's fine as long as you know all the wires are in tack
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
    dappa5's Avatar
    dappa5 is offline DO WORK! (if u can)
    Mar 2009
    S.W.FL
    1,850
    39 Post(s)
    yes wire from the amp to behind the h/u and wire directly into the harness (instead of speaker wire from h/u) remember to isolate (tape up) the unused wire
    i use a product called 9 wire it provides all 4 speaker wires (color coded same as harness ) and also has a remote wire all in a nicely shielded case (bout the size of 4 gauge wire)
    feedback thread
    http://www.caraudio.com/forum/showth...appa5+feedback
    lol the moderators here are GODS word to the wise
    "don't cross them lol
    Xen's Avatar
    Xen
    Mar 2012
    Tampa, FL
    1 Post(s)
    Aww sweet I like that 9 wire sheet, I will be making my order insta from there., Thank you soo much. I do however have one more question, does it matter what gauge I need. I have Rockford Fosgate P450.4 Channel Amplifier and The coaxial's I am running are Rockford Fosgate P1675(6.75) and Rockford Fosgate P1694(6x9), Of course then again I don't know if it will make a difference seeing the my door wires are stock wires running to back of HU.
    dappa5's Avatar
    Mar 2009
    S.W.FL
    1,850
    39 Post(s)
    Quote Originally Posted by Xen View Post
    no the 9 wire is plenty big / I've run considerably more power thru it
    feedback thread
  1. 4 channel amp wiring
    By bdisslimm in forum Wiring, Electrical and Installation Help
    Last Post: 02-02-2007, 01:51 AM
  2. 2 channel amp wiring options
    By derek33 in forum Wiring, Electrical and Installation Help
    Last Post: 03-30-2005, 10:21 AM
  3. Eclipse (or any 4 channel amp) Wiring/Setup Help
    By downsider in forum Amplifiers
    Last Post: 11-16-2003, 09:25 AM
  4. Eclipse (Or Any 4 Channel) Amp Wiring ?
    By downsider in forum Speakers
    Last Post: 09-10-2003, 06:48 PM
  5. 4 Channel amp wiring question
    By Croat23 in forum Wiring, Electrical and Installation Help
    Last Post: 11-06-2002, 09:02 PM
