Results 1 to 5 of 5
Reload Thread: Amp power wire question
    Cathlock's Avatar
    Cathlock is offline Member
    Jan 2004
    Utah
    45
    43
    Question: I have an 5 ch. amp 40x4 rms / 130x1 rms (sub ch) 4 ohms "The guy" at the audio store said I need an 100w amp kit which contains an 10 g wire with 30 amp fuse. I thought I would need at least an 8 g wire? I will be running two 10 inch 8 ohm subs (wired in parallel)...any thoughts
    Rockman's Avatar
    Rockman is offline CarAudio.com Elite
    Nov 2002
    topeka
    518
    Re: Amp power wire question
    I would go at least 8ga. I wouldn't run 300 watts thru 10ga.
    Car 99 Toyota Solara SLE V6
    HU Clarion DXZ835MP
    Front Speakers Infinity 6 1/2 Kappas
    Front Amp Crutchfield CR4X50
    Subs Kicker 12L7's
    Harrison Fmods
    Sub Amp PPI PC 2600's
    pavengmike6's Avatar
    pavengmike6 is offline Senior VIP Member
    Feb 2004
    florida
    497
    I agree with rockman. Why do things more than one time. I would even go with a 4 ga wire to a terminal block, and split it there. Only for this reason. If you are like the rest of us, YOU WILL ALWAYS WANT MORE. If you think ahead and have your system expandable you will not have to run power wire again. ALSO the gound wire in most amp kits are WAY TO SMALL. I always go one size up on my ground wire. It will save you a lot of problems later on.
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    30
    3,509
    I agree with pavengmike6. Go with a 4 ga. In case you ever expand in the future. Got to wal-mart and get a 4 ga wiring kit there. They have a pretty nice one with everything you need for $25 or so. It is a sochse efx. Has rca cables. 16 ft of 4ga red power. Distribution block and 80 amp fuse and holder and more.
    allyourblood's Avatar
    allyourblood is offline kill the fakes
    Jan 2004
    San Diego, CA
    319
    'nother vote for 4ga. don't go with anything less.
    abe m.
  1. Need a lil help all.
    By TimberJon in forum General Discussion
    Last Post: 03-10-2004, 06:06 PM
  2. 1/0 wire, distro block question
    By bobo244 in forum Wiring, Electrical and Installation Help
    Last Post: 01-23-2004, 09:12 PM
  3. fosgate amp question true power?
    By davidfre21 in forum General Discussion
    Last Post: 01-03-2004, 05:53 AM
  4. Can 8 awg power a 750w amp?
    By danfortner in forum Wiring, Electrical and Installation Help
    Last Post: 11-23-2003, 03:52 PM
  5. help NO POWER PLEASE! URGENT
    By Alpine4life in forum General Discussion
    Last Post: 10-08-2003, 04:17 PM
