Results 1 to 5 of 5
Reload Thread: Subs not hitting hard enough
    SwordMstr23's Avatar
    SwordMstr23 is offline Junior Member
    Jan 2004
    St. Petersburg, FL
    I recently installed 2 Rockford FOsgate 10" subwoofers and a rockford fosgate amp. After installing this equipment and turning it on the subs were working but were not hitting nearly as hard or with as good quality as they should have been (i have heard this set up before and know what it should sound like) To maintain a stock look i kept my stock head unit and used a adjustable power converter to allow me to plug in the amp, some people have suggested that i have the polarity mixed up, but would it be mixed up at the power converter or subs? I'm almost certain the subs are wired right seeing as how i followed the diagram in the instructions exactly. Any help would be appreciated
    SuBXeRo's Avatar
    SuBXeRo is offline Member
    Mar 2004
    New Jersey
    31
    47
    Re: Subs not hitting hard enough
    that happend to me once i reversed the polarity. they cancel eachother signals outt and well for me i had no bass and just alot of pitter patter movement. the confuision would be at where the wires meet the sub. lwell for me i have svc subs so my left is always positive. kinda like that. but maybe your amp just isnt getting enough ppower mabye connections arent good, make they are bridged correctly or however u wired it pending on what kind of amp. it could also be box type
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    32
    2,393
    Are your gains set correctly? How much power does your amp put out? (RMS) how much do your subs need?
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
    Jan 2004
    St. Petersburg, FL
    Thanks for teh advice, as for my amp it puts out 400watts x 2 RMS and my subs take 400watts RMS a peice thabks again
    worm's Avatar
    worm is offline Member
    Jan 2004
    NJ
    33
    60
    One of my friends had these same problems with Rockford amps. Very confusing because it seems like everything is right but its just not hitting hard. Using the stock head unit compared to an aftermarket can make a big difference, so you may want to look into that.
  1. yet another "my subs not hitting like i want them to" thread...
    By allyourblood in forum General Discussion
    Last Post: 02-22-2004, 04:28 PM
  2. i want some hard hitting 8's or 10's
    By phil7468 in forum Subwoofers
    Last Post: 09-08-2003, 11:05 PM
  3. Replies: 40
    Last Post: 09-06-2003, 12:46 PM
