Results 1 to 3 of 3
Reload Thread: 2 12" CVX Kicker subs, whats the best setup?
    ajwggns's Avatar
    ajwggns is offline Junior Member
    Feb 2012
    tallahassee
    Need help with my setup in my '06 impala, I have 2 12" kicker subs dual 4 ohms 750 rms. Dont wanna upgrade my alt. and im on a budget.
    1. should i get a yellow top battery?
    2. went on sonicelectronix and they have a program that helps find amps according to what subs you have. the number 1 amp was a
    Hifonics HFi1500D
    RMS Power Rating:
    4 ohms: 500 watts x 1 chan.
    2 ohms: 1000 watts x 1 chan.
    1 ohms: 1500 watts x 1 chan.
    Max power output: 1500 watts
    The amp i thought was pretty good was
    Power Acoustik D1-3000D
    RMS Power Rating:
    4 ohms: 900 watts x 1 chan.
    2 ohms: 1,300 watts x 1 chan.
    1 ohm: 1,700 watts x 1 chan.
    Max power output: 3,000 watts x 1 chan.
    Since my subs are 4 ohms should i look at the 4ohms output wattage on the amps or what? can someone explain why the hifonics is rate higheror is it just the name brand is the reason why its higher?
    3. Is it necessary to do the big 3 with my kind of setup?
    4. Should i use a cap?
    VisceralSound's Avatar
    VisceralSound is offline CarAudio.com Elite
    Oct 2011
    Rochester, MN
    1,606
    20 Post(s)
    Re: 2 12" CVX Kicker subs, whats the best setup?
    1. In my '99 malibu I was running 1k watts and I didn't need a second battery, but since you'll need to run it at 1 ohm it might be something to look into.
    2. If your content with running with the CVX's (I've never used Hifonics) but it should be fine brought down to 1ohm
    3. Big 3 is good for anything (1/0gauge)
    4. No
    *edit* the minimum gauge I would go with would be 4gauge, but if you want to invest more into it so you don't have to worry, go straight for 1/0 gauge wire for Power/Ground.
    References: BigSix,
    This industry is about innovation and setting your own path
    ajwggns's Avatar
    Feb 2012
    tallahassee
    should i get a yellow top battery to replace my stock and run everything off the on battery
  1. Im going to buy some new subs whats the best i can get for around 800
    By braxton23 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 01-29-2011, 04:51 AM
  2. I have three 12" subs, whats the best amp?
    By Nyris221 in forum Amplifiers
    Last Post: 02-08-2005, 10:19 PM
  3. Replies: 26
    Last Post: 09-28-2004, 09:49 AM
  4. Replies: 8
    Last Post: 02-11-2004, 11:38 PM
  5. Whats the best 8" subs?
    By dextrous in forum Subwoofers
    Last Post: 06-16-2002, 10:41 PM
