Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: Subs just don't sound "right"
    clysports's Avatar
    clysports is offline Junior Member
    Feb 2012
    Carmel, IN
    Hey guys, I'm new here and pretty much joined for this one problem but I will stick around if it gets solved
    Anyways, what's happening is my subs just don't sound right. It is hard to describe, but it sounds too much like hitting a drum, where I want low rolls instead.
    I haven't always had this problem, a couple months ago when I first got the set up they sounded great and loud, Perfect. However, the amplifier stopped working correctly so I sent it in and they fixed it and its back. Upon hooking everything back up, the problem began.
    I have a 2200w Boss Audio Amp, model CE2200M to be exact. Two Type R's, 12 inches, and 4 ohms. The wiring is Install Bay AK02, 1/0 gauge.
    When I watch the subs play, it appears that the sub on the left is playing at the opposite time of the sub on the right, and they are cancelling each other out. I have no idea if that is true, but it appears to be this way.
    Also its a ported enclosure, and I have a Jeep Wrangler if that means anything. (no rear seat, or else this wouldn't fit!)
    Thanks in advance for the help! I can provide any more info you guys need.
    clysports's Avatar
    Feb 2012
    Carmel, IN
    Re: Subs just don't sound "right"
    Oh and the final thing that probably you need to know, the head unit is a Kenwood unit.
    I cant recall the exact model but I can go get it if you need. I use the RCA red and white output from the HU as the input for the amp. Also, there are three settings on the amp, crossover frequency(i think, not sure what it is though), bass boost, and bass level. I have toyed around with those, but still can't find a good setting.
    dappa5's Avatar
    dappa5 is offline DO WORK! (if u can)
    Mar 2009
    S.W.FL
    1,841
    polarity
    sounds like pos and neg are reversed on one sub
    dbl check all wiring
    feedback thread
    http://www.caraudio.com/forum/showth...appa5+feedback
    lol the moderators here are GODS word to the wise
    "don't cross them lol
  4. Thanks clysports thanked for this post
  5. #4
    DoesDad's Avatar
    DoesDad is offline CarAudio.com Elite
    Dec 2011
    Tulsa, OK
    1,973
    26 Post(s)
    ^^^x2
    You definitely got something wired up wrong. I wouldn't play these too long that way. You'll see the magic smoke soon.....
  6. #5
    esmokah's Avatar
    esmokah is offline Dabbed Out
    Apr 2011
    Wisconsin
    369
    sounds like polarity to metoo. swap the pos and neg of one sub around
    Head Unit: Pioneer avh-4300dvd,
    Front Stage: Ascendant Audio 6.75", Massive Audio 28mm tweeters
    Rear Fill: Massive Audio CK6-3 6x9 Woofers
    Amps: PPI Phantom P900.4, Sundown Audio SAZ-2500D
    Sub: RE Audio XXX 12" 2.25^3 Tuned to 32
    They sell Kicker at Wal-Mart now. That's saying a lot..
  7. #6
    SourDeez's Avatar
    SourDeez is offline CarAudio.com Veteran
    Apr 2007
    Fuqy u
    4,129
    62 Post(s)
    definitely bad wiring
    and if not, its the amp (obviously it isnt the woofers, box, or jeep)
    Headunit - Stock cassette player - Pioneer P9400
    Front Stage - Pyle 8 inch subs (1000 watt peak!!) - Polk DB6.5 (about to be CDT 6.5s)
    Rear stage - Deleted (stolen) - Deleted
    Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) - Two SA12's built by Corey
    Sub amp - Pyle 8000w peak!! (spl edition) - AQ2200
    Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable - Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
  8. #7
    keep_hope_alive's Avatar
    keep_hope_alive is online now Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,120
    28
    128 Post(s)
    the above answers... or - only one sub is working and other is just moving it.
    redo your sub wiring. take pics of the connections and we'll comment (nicely)
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
  9. #8
    brandinooooo's Avatar
    brandinooooo is offline Woot Woot
    Dec 2010
    Stantonville, TN , Anchorage, AK
    22
    730
    Hate to say it but, you should get a new amp. Boss isn't a very good company for amplifiers. We can always help you find a cheap alternative that would outperform that amp and would work a lot better on those subs.
    HU - Kenwood KDC-HD545u
    Front Stage - Stock
    Amp -
    Rear Stage - Stock
    Amp -
    Sub - HDC318 6cuft tuned to 35
    Amp - Audiopipe 1500d
    MY BUILD LOG - http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/526429-02-tahoe-aq-build.html
  10. #9
    clysports's Avatar
    Feb 2012
    Carmel, IN
    Yep! One of the wires in the box got wired up backwards. I noticed that the subs were playing opposite of each other haha.
    And I know Boss isn't a great brand, but I got it off a friend. I will probably be looking to get a different amp sometime in the future but I don't have enough money right now.
    I need to build up the rest of the system first anyway, my HU isn't the best, and the speakers could use improvement. The boss will work for now!
    thanks again guys!
  11. #10
    dappa5's Avatar
    Mar 2009
    S.W.FL
    1,841
    Quote Originally Posted by clysports View Post
    thanks again guys!
    so do I win?
    feedback thread
  12. #11
    clysports's Avatar
    Feb 2012
    Carmel, IN
    Quote Originally Posted by dappa5 View Post
    so do I win?
    i guess so you put it first haha
    thanks again
  13. #12
    May 2009
    Nebraska
    2,917
    14 Post(s)
    Just be sure to stay around! You could really learn a lot.
    Quote Originally Posted by globalminds_ent View Post
    people think that companies are so much better than each other when it comes to amps, but this is all a game people..all of this **** is the same, now some are better than others but in the end all of this **** is the same. These companies want u to fight over who is the best. When honestly there is probably 2 or 3 huge companies that make every single amp on the planet. Wake up people.u don't no who owns this stuff and u don't know who owns these build houses.
    Quote Originally Posted by benbenondatrack View Post
    you dont even got no swag anyway
  14. #13
    dumple's Avatar
    dumple is offline What's in your trunk?
    Sep 2006
    Philly
    25
    8,308
    well heres your problem..
    Alpine 9887 w/ Bluetooth
    Kicker SX700.4
    Phoenix Gold Ti 65cs
    Mpyre 65m
    Kicker SX900.2
    Stereo Integrity Magnum v1 claw
    cream jean of sound 8======D~ _
    refs: Lil_KB, jesusbasscadill, Crzy, Wkbdkid, bigwheel15, groggy23, kenbei, Belunt (awesomebox), Nissan, shallowfu, jonnybusa, alxmlr789, pioneerpimp, peas247, ravens9322, sundownz, audiobahnuser18, [email]nbesaw2@new.rr, jared530, brenTgrillzem, Revrider1
  15. #14
    myjaja's Avatar
    myjaja is offline Audioque
    Sep 2006
    San Antonio, Tx Posts: 143,632 _____<^>*_*<^>_____
    3,410
    30 Post(s)
    Glad you got it fixed and make sure to turn down your bass boost all the way and hopefully youre gain is set just right. After all, a lot of "Boss" owners tend to turn up everything all the way. lol
    Refs: sbcaprice305, mattmcss, systembumping, LeofromtheH, audiobahnuser18, stishdr, wcarson8911, jnoel, mr_kebo, 93 saturn sl2
    HU: Home stereo converted to dc
    Speakers: Stock
    Subs: 6 1/2 home sub
    Amp: off the stereo
    Wiring: extended power cord
    neon lights: Christmas lights duct taped to frame
  16. #15
    JoshC's Avatar
    JoshC is offline The Taco MASTA
    Jul 2011
    waco, tx
    2,435
    3 Post(s)
    max knobage is totals boss
    Pioneer DEH-P9400BH-CDT HD61s-Kenwood&AQ-Obsidian 12
    Doors covered inside and out in AT 60mill
    Sold to: akheathen, audiobaun----Traded with: Mylows10-------Bought from: fasfocus00, Ram_Designs, Mylows10, power-fanatic07, Argento
  1. It just doesn't sound right!! Help a newbie..
    By julesMI in forum Wiring, Electrical and Installation Help
    Last Post: 04-15-2011, 06:10 AM
  2. Kicker L5's just don't sound that bad!
    By jimmyslide in forum Subwoofers
    Last Post: 06-21-2008, 08:51 AM
  3. Sub boxes don't need to be perfectly square right?
    By Jeepaudio in forum Subwoofers
    Last Post: 03-21-2004, 03:15 PM
  4. Replies: 5
    Last Post: 03-01-2004, 03:16 PM
  5. &quot;Esoteric&quot; components
    By 89S4 in forum Amplifiers
    Last Post: 01-23-2002, 07:03 PM
