Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Reload Thread: Here is an idea for cheap battery terminals.
  1. #16
    slim2fattycake's Avatar
    slim2fattycake is offline rolling right along
    Jun 2008
    In the Stars
    2,192
    158 Post(s)
    Re: Here is an idea for cheap battery terminals.
    Quote Originally Posted by akheathen View Post
    you could., but unless it is visible, a stainless brush will knock down the coat ok. no harm in scuffing better, though. just like when mag brazing aluminum. years back, I've learned about the conductive properties (surface and core) corrosion resistance, thermal limitations, etc. probably the same or similar article. based on actual thorough scientific test data. from what i remember: among most common metals, silver and aluminum rated the highest in conductivity. in fact, aluminum was utilized for half a century in homes and automotive, due to both it's cost, and conductive properties. there would be less of a voltage drop over long runs. however, it's ampacity is real low, corrosion resistance is horrible, and both these factors lead to more of a fire hazard, and short life-span. for example- 1/0, or 2/0, (don't remember which) has a rated ampacity of mere 60a now, copper, is pretty much in the middle of the scale, i believe right above gold, which brings me to the next point. the most surprising thing i have seen to most people, is that gold is altogether not as conductive as you would think. so, why does it make for an excellent terminal/contact coating? well, it's unique properties provide 2 key benefits. first, we all know of it's high corrosion resistance. who has ever seen corroded gold? second, it has an uncanny ability to stick well to itself, literally, the contact it makes forms an electrical bond between 2 pieces, and somewhat of a good bond to other metals. look up magnet wire ratings, and compare the wire resistance of different materials of the same thickness. think about just how short copper mag wire is in a 4ohm coil, and then how long it is in an aluminum coil.
    edit: i stand corrected. had to go back and look it up, and mag wire rates aluminum lower than copper. 1.6 times more aluminum than copper for the same rating.... i'll have to research more...
    you don have to research more. aluminum is nowhere near as conductive as silver or copper. it is cheaper is all.
    SPL-Lab REP
    Want an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has more features and support? PM me.
  2. #17
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep
    Sep 2009
    monterey , ca
    54
    22,442
    142 Post(s)
    1 Thread(s)
    6016 Post(s)
    these are what i use
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  3. #18
    CRXBMPN's Avatar
    CRXBMPN is offline Moe Bass
    Jul 2004
    Maine
    37
    8,922
    45
    1 Post(s)
    353 Post(s)
    i'd love some of those for my freaking batcap
    Team Bass Lovers Of MainE/The Loud Crowd/CentralMaineBassHeads
    2k5 SLAP Stock 2 National Champion - I feel old...!
    2009 Mazda 5 Mini Van - Shocker/Sundown 12s + 2x Sundown NS1 = 155.3 p.b. so far...
  4. #19
    mylows10's Avatar
    Sep 2009
    monterey , ca
    54
    22,442
    142 Post(s)
    1 Thread(s)
    6016 Post(s)
    i can give you the email of the guy that made them for me
    ---------- Post added at 02:12 PM ---------- Previous post was at 02:11 PM ----------
    i have these guys for sale if interested
  1. Got an idea for a new forum...
    By Randy Savage in forum General Discussion
    Last Post: 08-16-2005, 01:18 AM
  2. Cheap Battery Terminal + Wire Gauge Adapter
    By ss3079 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 03-23-2005, 01:44 AM
  3. JMAC!! thought of an idea for porting my box
    By tommyk90 in forum Enclosure Design & Construction Help
    Last Post: 11-06-2003, 03:22 PM
