Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 60 of 60
Reload Thread: A girl doing a guys job...help! Amp not working and now stereo too!
  1. #46
    Imtjnotu's Avatar
    Imtjnotu is offline Me Gusta Edition
    Nov 2006
    San Diego CA
    12,324
    134 Post(s)
    Re: A girl doing a guys job...help! Amp not working and now stereo too!
    If u can get a dmm it will makes things easier even the cheap ones from walmart will do
  2. #47
    disturbed471985's Avatar
    disturbed471985 is offline CarAudio.com Veteran
    Jun 2009
    Greenwood, La
    28
    6,652
    11 Post(s)
    ^^^ my $10 one does the job...
    RIP Christopher Maynard Martin "My heart"
    HU - Eclipse CD7000 For Sale
    Front Stage - 4 Silver flute 6.5's & 4 Seas Prestige tweets 1 set of each left
    Front Stage amp - DB Drive A7 125.4 Sold
    Subwoofer - 3 Skar VVX 10's (Looking for 4th so I can run amp at .5ohm) Sold
    Subwoofer Amp - Skar SK-2500@.67ohm Sold
    Box - 4.25cf tuned to 30hz using a 6" internal aero 15" long.. Sold
    Wiring - Knukonceptz everything, Big 3, Sprinter S12V370F & HC1800 Sold
  3. #48
    Shinju's Avatar
    Shinju is offline CarAudio.com Veteran
    Aug 2008
    Seattle
    4,767
    23 Post(s)
    Holy ****! Clean up those wires on the terminals before you catch something on fire! Get some Spade Connectors for those wires to fit into the terminals bare wire like that = bad news.
    Ok commence the trolling.
    List of Ref's Just ask, Shinju on all Car Audio Forums!
    Flawless Ebay Feedback User: Shadox2k2
  4. #49
    pickup1's Avatar
    pickup1 is offline Audiosystem. .
    Aug 2005
    Roanoke,TX
    48
    6,702
    17
    28 Post(s)
    4 pages and not one pic of the op....
  5. #50
    Robert 2001's Avatar
    Robert 2001 is offline Senior VIP Member
    Apr 2011
    Lakeland, FL
    273
    Find you. a dmm for testing. Get some good #8 wire for power and grounds as a true 400 watt amp should have around 40 amp fuse. Its possible u burnt the wire your using as it looks pretty small youll need a dmm to find out. Test the voltage at the amp both with and without a load on the amp. Verify signal voltage to subs and ohm loads. Gl
    2001 dodge ram ext cab
    Kenwood kdc series hu
    Infinity 6x9s and 6s
    2 Kicker L7 12s
    US Amps Xterminater XTD 2000d
  6. #51
    SMFJ's Avatar
    SMFJ is offline Senior VIP Member
    Nov 2010
    Albany, Georgia, United States
    304
    4 Post(s)
    Quote Originally Posted by matt_bennett05 View Post
    You may have better luck trying to power sub off the headunit. Those American Pro amps literally don't look like they have more power than a headunit.
    And be sure that you don't have a loose battery terminal or have it wired into the incorrect factory wires.
    Don't doubt the American Pro as a beginner amp. Mine pushed my hifonics 12s pretty hard before I burned it up from running at bridged at 1 ohm. Lol. That first system bring back so many memories. I actually thought I was pounding.
    X2 on the grounds. I'd also recommend upgrading battery and engine grounds in the front.
  7. #52
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    22
    3,406
    28 Post(s)
    Yea, you gotta get some 8 gauge wire on there. That looks like 12 gauge wire or something, way too small >.< And I don't know if you've done it already, but I'd check the fuses too. Basically anything you hooked up, double check it all to make sure it's still securely connected.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  8. #53
    whitedragon551's Avatar
    whitedragon551 is online now Moderator
    Mar 2009
    MI
    12,487
    82 Post(s)
    Alright before this goes any further. Im going to remind all of the older members here there is no trolling outside of the Dome. Consider this your first and only warning.
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    A Technology Related Blog
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  9. #54
    ahole-ic's Avatar
    ahole-ic is offline Banned
    Jan 2010
    Ivory Tower
    2,936
    Oh I thought this thread was about licking vajines.....
    clean up wiring. Make sure grounds are good.
  10. #55
    stevew007's Avatar
    stevew007 is offline CarAudio.com Veteran
    Aug 2006
    west sacramento
    2,448
    6 Post(s)
    my bad! that was very rude of me.please accept my apology.sorry
    REF'S 96maxgle, LcKmyblls, djman37, nomad40, el_chupo_ , jep772, got focus?, platestacker45, randyrsx, duece212,DB_DRAG_SPL, ProjectPechkin
    http://www.myspace.com/colorado_basswarz
  11. #56
    MikePresJr's Avatar
    MikePresJr is offline Junior Member
    Feb 2012
    Claremore, OK
    Did you check the fuses? Any weird smells? do the sub/speakers work plugged into any other outputs? Does the deck work sans amplifier? Is your inline fuse blown?
  12. #57
    dbjunior's Avatar
    dbjunior is offline CarAudio.com Elite
    Jun 2009
    ma
    637
    1 Post(s)
    Try a different source if you get another set of rcas and hookup an iPod or something to the amp and get no sound the amp is bad. If it work's it's either your rcas or headunit
    bought from MBROOKY, johnny law.Lulz, subzero, tc3k101
    sold to mytrunkslamz , vitveet, cd6551, martiandancer31 (x2), pro-rabbit, whytellyou
    Trade with cf2004
  13. #58
    skylineTT's Avatar
    skylineTT is offline bass=sekz
    Jun 2007
    Dallas/Raiderland
    4,003
    5 Post(s)
    You can go to harbor freight and get a red DMM for 3 dollars. Works fine for basic car audio use.. Go to walmart and buy 3.5mm aux jack to RCA wire adaptor and that will plug into the amps RCA's and the other end will plug into an Ipod headphone jack. You can test signal with that.. If it doesn't work that way, It is surely the amp. Get 8g Power wire from the battery to the amp and an 8G ground if you dont have one already. If it doesn't work then, your amp is shot.
    Refs: Dipitydoo, appollyon, bad95gt, revrider1, jwh1598, ampjunkielikeme, deathpenalty18, ssackett, snoopysnooper, corey0928, SPLAudio, Clifff150, CL1CKCLACK, ShawnT, West + more
  14. #59
    skylineTT's Avatar
    Jun 2007
    Dallas/Raiderland
    4,003
    5 Post(s)
    Also, get a small piece of wire and bridge the remote terminal to the positive batt. terminal. This will keep the amp on nomatter what during testing. It eliminates the head unit's remote amplifier function so it helps diagnose amplifier failure.
  15. #60
    Falcons's Avatar
    Falcons is offline that **** i dont like
    Jan 2011
    Albion, New York, United States
    5,087
    18 Post(s)
    still dont know if this is legit or not. lol
    Things to look forward to:
    (2) 10" or 12" imperium audio designs subs
    set of PHD MF 6.5" comps
    Completely seal off and deaden my doors
    aquire a 2k amp
    aquire a 2 channel amp for front stage
  1. Anyone Help!! Amp not working right
    By ioseida in forum Amplifiers
    Last Post: 03-03-2011, 11:39 PM
  2. Replies: 5
    Last Post: 11-15-2009, 06:48 PM
  3. quick help amp not working
    By aircruiser in forum Wiring, Electrical and Installation Help
    Last Post: 07-08-2009, 06:43 PM
  4. How do you guys wire multiple amps...
    By joem1cha3l in forum General Discussion
    Last Post: 10-02-2007, 12:02 PM
  5. Amp not working need help fast!
    By QuadPioneer in forum Subwoofers
    Last Post: 03-07-2003, 08:32 PM
Tags for this Thread
