Results 1 to 4 of 4
Reload Thread: Sub problem
    rharlow83's Avatar
    rharlow83 is offline Junior Member
    Jan 2012
    st. Louis, mo
    Sub problem
    The other day my sub just quit as i was driving. At first I thought my amp had overheated, as it has done before, but after being parked fr several hours still nothing so i started checking all my fuses, then wires and everything is good. Now i have noticed that the sub will still hit if I press in on the cone. I pulled the sub out of the box and was checking for any discoloration or anything that ight indicate a burnt out voice coil but everything appears fine. So what im wondering is. What is the problem and is it something i can fix? Or am i going to have to replace the sub?
    akheathen's Avatar
    akheathen is offline trianoacitol contraceptiv akheathen is a Supporting Member of the forum!
    Jan 2011
    Anchorage AK
    36
    2,355
    1 Post(s)
    250 Post(s)
    Re: Sub problem
    sounds like you broke either a tinsel lead, or it's connection to the coil, or a portion of the coil leads on the cone, if it goes up to the cone and connects under the dustcap. not knowing your abilities, nor the sub in question, i'm not sure if you would be able to fix it yourself. a pic of the sub where the tinsel leads are going to the cone, and dustcap would help.
    *IF I have forgotten to exchange feedback, please let me know*
    i buy broken amps....
    No, i will not "gift" paypal. please do not even make it awkward by asking. if the fees are an issue, I am usually inclined to add them. unless you have discount elsewhere, shipping is through usps flat rate, through usps parcel post, or through the roof..... i am in alaska. thanks
    -Heath H-
    sacsking916's Avatar
    sacsking916 is offline stayin high an loud
    Apr 2009
    emerald triangle..home of da trees
    6,428
    323 Post(s)
    Re: Sub problem
    can you elaborate more on the system? as fas as what you have?
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
    Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
    Apparently I was called out, or called a goat fucker, or something. I really have no idea. Im just along for the ride at this point.
    Quote Originally Posted by CRXBMPN View Post
    King James has nothing on King Sac!
    Robert 2001's Avatar
    Robert 2001 is offline Senior VIP Member
    Apr 2011
    Lakeland, FL
    273
    Re: Sub problem
    Measure the subs impedance see if u still get a coil reading. Could be the coil or tinsel lead as stated. U could possibly repair the tinsel if broke or have it reconed if r2 he subs worth the money.
    2001 dodge ram ext cab
    Kenwood kdc series hu
    Infinity 6x9s and 6s
    2 Kicker L7 12s
    US Amps Xterminater XTD 2000d
  1. sub problems
    By v8s10 in forum Subwoofers
    Last Post: 10-21-2002, 02:06 PM
  2. MTX Sub problems
    By pfw3_1229 in forum Subwoofers
    Last Post: 05-28-2002, 06:05 PM
  3. Sub Problems
    By CashMoney in forum Subwoofers
    Last Post: 05-22-2002, 11:31 PM
  4. 96 2DR Chevy Tahoe Sub Problem
    By Fomskwok in forum Wiring, Electrical and Installation Help
    Last Post: 05-06-2002, 05:15 PM
  5. sub problems
    By BASSBOY in forum Subwoofers
    Last Post: 02-26-2002, 10:58 PM
