Results 1 to 8 of 8
Reload Thread: 4 Gauge vs. 8 Gauge wire
    ckunke002's Avatar
    ckunke002 is offline Senior VIP Member
    Oct 2011
    Portland, OR
    495
    80 Post(s)
    I have 2 amps and I currently have one 4 gauge power wire coming back from my battery to a distribution block and splitting into two 8 gauge wires. One of the amps is 300 watts and the other is 350. Do I need a bigger than 8 gauge wire powering my amps, or does it work since it's a 4 gauge wire splitting into 8 gauge? It's the size that they sold to me at my local car audio store so I'm just trusting I didn't need a lower gauge wire. I don't understand how this all works so please help!
    Thanks a lot!
    Dr. Slam's Avatar
    Dr. Slam is offline Slamming hoes n trunks...
    Nov 2010
    Chicago Heights, IL
    639
    120 Post(s)
    Re: 4 Gauge vs. 8 Gauge wire
    Your good bro. I have a 300 watt amp and a 480 watt amp ran the same way you have, 4 gauge to the dist block, 8 gauge to amps.
    Head Unit: Alpine Ixa-W404
    Front Stage: Alpine Type X 5.25 Component Speakers
    Front Stage Amp: JL 300v2.2
    Rear Stage: 4 Infinity Kappa Perfect 6x9s
    Rear Stage Amp: Stetsom 600.4
    Subs: 2 Sundown Nightshade V.2 15s Spl Coil Upgrades
    Enclosure: Building 6^3 ft Tuned to 32 hz
    Sub Amps: 2 Sundown 3000ds
    Batts: kinetik 1400, 2400, Looking for 2 more 2400 equivalents or better
    250a Mechman HO Alt
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    Yep you're fine...8g's limit is around 80A, which comes out to be ~1000w. 4g's limit is 150 which is around ~2000w. Plus those runs of 8g you are doing are probably so short the wire can handle even more.
    Bggd_GMC's Avatar
    Bggd_GMC is offline Low & Loud
    Oct 2011
    Fresno, CA
    522
    48 Post(s)
    can you cut strands off a 4awg wire to fit in a 8awg terminal?
    SPLluminator's Avatar
    SPLluminator is offline CarAudio.com Veteran
    Oct 2008
    GR, Michigan
    3,583
    19 Post(s)
    Quote Originally Posted by Bggd_GMC View Post
    Yes but they make connectors that are used for that as well
    Equipment for sale-220A alt, Eminence Delta 10" speakers, BNIB MB Quart Q4.80, (2) IA 20.1's (Newest Version), SI BM Motor w/ Basket, (2) Deka Intimidator G31 Batts, 2 RD Sonance 15's with baskets (need recone).
    Refs: Scott S, hornedfrog1985, dsmdan, Newageking, DBboom, R/T Pimp, SQcrewcab, Bumpin Buick, tangelo95, fearof85,
    coma_toast, Blackga, spy, LouisianaCRX, Oxsign, etc...
    Bggd_GMC's Avatar
    Oct 2011
    Fresno, CA
    522
    48 Post(s)
    Quote Originally Posted by SPLluminator View Post
    ill look for some
    ckunke002's Avatar
    Oct 2011
    Portland, OR
    495
    80 Post(s)
    Thank you all a lot!
    whitedragon551's Avatar
    whitedragon551 is offline Moderator
    Mar 2009
    IL
    13,586
    42 Post(s)
    1424 Post(s)
    Depends on if the wire is a true 8AWG and 4AWG. What brand is it?
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
  9. Thanks 05trailblazer thanked for this post
