Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 83
Reload Thread: What's so wrong about mounting amp on sub box?
  1. #16
    Jan 2011
    Binghamton N.Y.
    2,334
    129 Post(s)
    Re: What's so wrong about mounting amp on sub box?
    it damages amps, and only noobs mount to the box without cushion. so cushion the ampagainst the box
  2. #17
    mylows10's Avatar
    mylows10 is online now B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,424
    141 Post(s)
    1 Thread(s)
    6010 Post(s)
    smaller amps and setups usually aren't a problem ,but yes cushion them,when you get into the louder and bigger amps is when you will have the issues
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  3. #18
    Imtjnotu's Avatar
    Imtjnotu is offline Me Gusta Edition
    Nov 2006
    San Diego CA
    12,626
    1589 Post(s)
    Quote Originally Posted by audiobaun View Post
    Huh??? First time added a sub to your box???
    fuuuuuuuuuuuuuuuuuuuuuuuuuu
  4. #19
    wenn_du_weinst's Avatar
    wenn_du_weinst is offline CarAudio.com Veteran
    May 2007
    4,633
    1275 Post(s)
    I've done mid 150's with my amp screwed to my box. No problems.
    I am protesting Skar by giving them added exposure in my signature.
  5. #20
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    35
    12,395
    2 Post(s)
    2522 Post(s)
    so much miss leading and out right wrong info here..
  6. #21
    disturbed471985's Avatar
    disturbed471985 is offline CarAudio.com Veteran
    Jun 2009
    Greenwood, La
    32
    8,361
    7 Post(s)
    1336 Post(s)
    ^^^^^^ Yes Sir..
    RIP Maynard "My heart"
    1996 Ford Explorer 4 door XLT
    HU - Eclipse cd-7100 "active"
    Front Stage - 2 Alphard mx60 mids- 2 Alphard mx80 mids - 4 Hertz ST25's
    Front Stage amp - 2 Alphard 200.4
    Subwoofer - Custom
    Subwoofer Amp- Soundigital 8.8k
    Box - 3.5cf tuned @ 33hz
    Wiring/Electrical - 4/0awg weld, JY 79.8Ah lithium, 290&370 hair JS Alternator
  7. #22
    Imtjnotu's Avatar
    Nov 2006
    San Diego CA
    12,626
    1589 Post(s)
    Quote Originally Posted by pro-rabbit View Post
    so please fill us in dustin
  8. #23
    ahole-ic's Avatar
    ahole-ic is offline Banned
    Jan 2010
    Ivory Tower
    2,936
    289 Post(s)
    I KEPT blowing my DD z2lv amp over and over because of this issue. The backs on those amps would literally vibrate off because the screws would back out. My box is fully resined and reinforced with threaded rod. It has very minimal flex. I ended up putting gorilla tape over those screws etc just to make sure that panel stayed on. I also use rubber washers on both sides of the amp mount. This way the screw doesn't transfer the vibration to the amp either. This makes the amp sort of hover away from the box and has lots of shock absorbtion. Since them I haven't blown any of my amps.
    Edit: The components in an amp that have any weight and will vibrate off are epoxied down. The other components such as transistors are screwed down. The board is screwed to a big piece of aluminum so it's not like it's in there flexing. THAT is why there was so much misinformation. The back fell off of my amps and shorted components within the amp itself. LOL that will do it every time. It sounds like a shotgun just went off in the car.
  9. #24
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    35
    12,395
    2 Post(s)
    2522 Post(s)
    There are a few amps out there that are known to have issues with this. However, any vibration that your amp is subject will not damage it unless as ecrack said, things fall off and BOOM....
    While at AQ we tested this theory in massive lengths which each amp. The short answer, unless something comes loose such as screws/bolts, there will be no ill affects from having your amp mounted on your enclosure.
    Again, as Ecrack suggested, using rubberized washers or other means of dampening can be done to help reduce that vibration. However, if you have a violent setup(creates a lot of force), you amplifier will be subjective to vibrations regardless.
  10. #25
    >>SQL<<'s Avatar
    >>SQL<< is offline CarAudio.com Elite
    May 2011
    USA
    1,457
    104 Post(s)
    Well I am not a noob - I am 38 years old and have have a system in every car I have ever owned since I turned 16, thats 22 years for you math challenged.
    I would prefer to mount them somewhere else but there is no room.
  11. Dislikes ChucklezZ disliked this post
  12. #26
    May 2007
    4,633
    1275 Post(s)
    there is no place to mount your amplifier in a car that it will be free from vibrations....
  13. #27
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    35
    12,395
    2 Post(s)
    2522 Post(s)
    Quote Originally Posted by wenn_du_weinst View Post
    Exactly!!
  14. #28
    Jun 2009
    Greenwood, La
    32
    8,361
    7 Post(s)
    1336 Post(s)
    Quote Originally Posted by crispin View Post
    How u liking the skars?? I planned on running them but no dual 1 option...
    Subwoofer - Custom
  15. #29
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    35
    12,395
    2 Post(s)
    2522 Post(s)
    Quote Originally Posted by disturbed471985 View Post
    here is a quote from a pm just few min ago...
    Bro I just got everything installed - MY God, it hits so low - much lower than my last 2 systems.
    really impressed - thank you.
    Thanks Bro!!!!!!!!
    not promoting or anything....
  16. #30
    Jun 2009
    Greenwood, La
    32
    8,361
    7 Post(s)
    1336 Post(s)
    Why cant company's offer more coil options!!!!!
    Subwoofer - Custom
