Results 1 to 8 of 8
Reload Thread: What materials do you need for adding a trunk battery?
    xmakeafistx's Avatar
    xmakeafistx is offline CarAudio.com Elite
    Mar 2011
    Kenosha, WI
    24
    1,089
    51 Post(s)
    Obviously I need a battery, wire, terminals. but beyond that what else might I need?
    I know there is like tons of stuff that is used for safety etc.
    What should I be looking to need when I come to this?
    Kind of nubby, but eh. Just double checking before I make an install mistake.
    Amp: None
    Sub: None
    HU: Parrot Asteroid Single Din
    Front Stage: Massive CK6X Component Set (one mid-woofer went out recently)
    Rear Fill: None
    Electrical Upgrades: None
    IonRL205's Avatar
    IonRL205 is offline DJ h4z4rdes
    Sep 2008
    Abilene, Texas
    2,449
    946 Post(s)
    Re: What materials do you need for adding a trunk battery?
    A bracket to secure your battery down.
    Headunit - Pioneer DEH-P8300UB
    Subs - None
    Sub Amp - 2x Crescendo 3kwp
    Front Stage - Polk Audio db651 Coaxial
    Front Amp - None
    Quote Originally Posted by zako View Post
    Most properly done 15 inch subwoofers are not suited for car audio use simply due to box size requirements.
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    thats about the most important thing, and be sure to cover up the poss. connection, so anything bouncing around wont ground it out, as I had a D A M N seatbelt buckle fall back under the seat of my x-cab,and grounded out my Stereo amp,and had to repair, as this could have been avoided by a simple plastic $3 cover, and cost me $200 after said and done to repair a $1000 amp? Who would have ever thought that would happen??It did to me(Jinxed!!).
    Mar 2011
    Kenosha, WI
    24
    1,089
    51 Post(s)
    Never would have even thought of that. But yeah I figured I would need something to keep it stable. I don't have anything in my car tied down whatsoever, which I'll need to fix once I upgrade no doubt. I'm thinking about putting the batt in the spare tire location. is this unsafe?
    Amp: None
    Sub: None
    Rear Fill: None
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    Whats Unsafe anymore??LOL! The new Equinox has a battery in the rear?Where you giong to put your spare?What kind of vehicle you have?The bolt down is what I use for a D a m n Good grounding point.I always build a false floor out of 3/4 plywood, and cover it with carpeting/or paint it black, or put it under existing carpet, and by the time you put the sub box in mount amps, it should be heavy enough tto stabilize Whatever??
    Jan 2011
    Binghamton N.Y.
    2,334
    129 Post(s)
    make sure you have something to cover the terminals with. i use rubber insulation with a bungee over to for extra security
    Mar 2011
    Kenosha, WI
    24
    1,089
    51 Post(s)
    Good one ^ Definately need that.
    Also to audiobaun I plan to remove my spare, It will be going into a 2003 jetta sedan. My car barley has any room to be doing anything false floor wise, i want to be able to use my trunk as much as possible. & I never thought to ground there. I might just end up doing that.
    Amp: None
    Sub: None
    Rear Fill: None
    audiobaun's Avatar
    Jun 2011
    Tx
    9,316
    27 Post(s)
    2169 Post(s)
    Spare tire i remove, scratch up the rod/bolt down run a washer down, then a nut, then my 8/4ga ground wire w a ring terminal, then another washer, then another nut, and sandwich it together, then place/bolt my spare back down Works just fine folks
