Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 49
Reload Thread: Kicker CVR vs CVX
  1. #31
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    Re: Kicker CVR vs CVX
    Quote Originally Posted by thedancer1987 View Post
    well im running 2 15 cvr's and there duel voice coil at 4 ohm and i have them briged to 1 ohm stable on a hifonics brutis 1700.1 mono amp and it hit super hard im hitten at least a 142 db,s im ganna be getten a hifonics brutis 2100.1 soon so im hopen its ganna hit pritty hard. my buddy is runnen 1 12 cvx in a 1.8 cubic foot sloted box with a 650 kicker amp and hes hitten a 141.1 db so i agree the cvx's are much better and can handle a lot more but still put out a lot of bass and clarity with a low watt amp but my suggestion is deff ither one u pick ither the cvx or cvr the hifonics brutis is the way to go for sure it sund realy good
    but my persanl suggestion would be if ur ganna run the cvr's the 1700.1 brutis would be grait but if ur ganna go with the cvx's prob do the 2100.1 brutis or the 2400.1 brutis and ull be dumpen hard lol oh and if ur tryen to stay in ur buget check out ebay u will get realy good deals hope u enjoy and i hope any thing i said helps
    You fail on many levels
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Kenwood DNX-692HD_____________ -Head Unit: Eclipse CD7100
    -Sub Stage: Focal KX40 16"_________________ -Sub Stage: Looking
    -Mids/Highs: Focal KRX & PHD AF____________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: Mosconi AS200.4_________________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: Mosconi AS200.4_________________ -Mid Amp: ^^^
  2. Thanks TheUnderFighter, THATpurpleKUSH thanked for this post
    Likes av83 liked this post
  3. #32
    Eddie_24's Avatar
    Eddie_24 is offline Member
    Jun 2012
    Ohio County, Kentucky
    64
    16 Post(s)
    LMFAO
    Don't even get me started on my opinion on the Brutus amplfiers, let's just say I'd never buy one again, and yes I owned one hooked to 2 CVR 12s, wired to 2 Ohms.
    I have 2 Kicker CVR 12s and I can tell you that there are a BUNCH of better sub woofers out there, but with them being my first pair of subs ever I can't complain, they banged like a mofo (when i had them hooked to a Kenwood 9105d).
    -I don't believe 2 CVR 15s did a 142 Dbs
    - Check out other brands of subwoofers, there's another world of subwoofers, explore. Kicker isn't the all be all, and this is coming from someone who has ran two CVRs for over a year. If you're willing to spend the kind of money you claim, why buy Kicker? There's better brands, I promise you.
  4. #33
    48mills's Avatar
    48mills is offline #PreludeBoy4Life
    Jun 2012
    Littleton, NC
    2 Post(s)
    id go with the cvx dual 2ohm, & with an audiopipe AP18001D. Which to have those speakers loud, which ever amp you do decide to get, im sure you'll end up getting an h/o alternator. If not the alternator, at least another battery. BUT . . . if your budget is within those prices, id say since you do have the room for a big box, get a big ported box tuned to your likings & you wont need so much power to be loud. The big box will help you be louder with less power than a small box which would need more power to sound as loud.
    iLive LOUD !
    d-_-b
  5. #34
    bgowdy's Avatar
    bgowdy is offline HE NEEDS SOME MILK
    Apr 2011
    Campbellsville, Ky
    7,837
    71
    2 Post(s)
    2487 Post(s)
    Quote Originally Posted by brodeisel View Post
    You need to get a different company for subs. Do you want to be loud, Low, sound good?
    wow......the funniest sig ive seen so far
    06 DODGE STRATUS SXT
    Subs: Sundown ZV4 15 D1 Rev1 Motor/Rev2 Softies
    Enclosure: 3.85 Cubes Net Tuned 36hz
    Amp: Soundstream Ta.3kw @ .5ohm
    Stock 120a Alt ~1 XS D3400 & 1 Kinetic HC1800 ~ Multiple runs of Bullz Audio 1/0
    Loudest Build Score ~ 148
    F.C.B.C. > 2010 450 Street 3rd Place Overall > 2011 450 Street Champion
    YOUTUBE SEARCH->bgowdy31 & bgowdy3131
  6. #35
    Full Tilt's Avatar
    Full Tilt is offline Bonafide MAFer
    Mar 2012
    Iowa
    1,977
    848 Post(s)
    If you're stuck on Kicker, the Hifonics BRZ1700.1d will supply enough power to make 2 CVXs hit (I'd recommend the CVXs vs the CVRs obviously, but it's all about how loud you want to get vs how much you're willing to spend). Depending on how your vehicle is set up, you may need a H/O Alternator. However, the Big 3 Upgrade and a bigger battery is sometimes enough. It simply depends on your application.
    Quote Originally Posted by T.I.K. View Post
    Careful, by those definitions Spider Monkey is a contributing member, I don't think he even knows what a subwoofer is.
    Quote Originally Posted by Truman View Post
    Thanks quackhead. Your the only person who agrees with me. Jesus Christ I have like 40 post and I've been called a ******* like 37 times
  7. #36
    Jan 2011
    Binghamton N.Y.
    2,334
    129 Post(s)
    Cvxs and cvrs are like comparing a small turd and a bigger turd. Both are pieces of shitttt. Only thing worth touching that kicker makes are kx amps solo xs and the warhorse....and they're all to expensive evn used. For ur budget get 2 sundown sa15s on a cheap 1500 like hifonics or mb quart or ap. Or an aq 1200d. My old single sa 15 was seriously twice as loud as this kids 2 cvx 15s don't touch kicker. Don't touch rockford. Don't touch jl. Don't touch alpine. Same philosophy has done me well
  8. #37
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    27
    3,488
    862 Post(s)
    Good job on having one of the biggest fails of first posts ever on this forum. Also, you bumped a 7 month old topic. GTFO!
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  9. #38
    jsluss17's Avatar
    jsluss17 is offline Senior VIP Member
    Oct 2011
    Scottsdale, AZ
    469
    144 Post(s)
    good thing people are recommending subs to the guy when it's 7 months old
  10. #39
    carsonevans's Avatar
    carsonevans is offline Junior Member
    May 2012
    Tampa, FL
    lk;adsfj;klds jflaelkf
  11. #40
    SebastianLynn's Avatar
    SebastianLynn is offline Junior Member
    Oct 2012
    Huntington, WV
    4 Post(s)
    So i am working on my first setup ever. From what i have seen, the CVXs are definitely better, but for a poor college kid who wants decent, not amazing, music, are the CVRs worth the money? I only want to spend a couple hundred on my setup. I don't want want anything competition and i don't really want to be heard from 3 miles away. i just want to be heard from maybe a couple cars away. And I'm not one who can tell, nor really cares about, the difference between good sound and amazing sound. So the question is, are the CVRs worth it for me?
  12. Dislikes Bettr n' Revrse disliked this post
  13. #41
    audiobaun's Avatar
    audiobaun is offline CarAudio.com Veteran
    Jun 2011
    Tx
    9,325
    27 Post(s)
    2171 Post(s)
    Quote Originally Posted by SebastianLynn View Post
    My cvr DVC4ohms 10s are banging theyre a ss off with an old school white Autoteck Mean Machine 66 on ea sub, at 1.6 cu ft ported ea.Hitting the lows nicely,and [email protected] ea.Just have to have a good box, and some room, they will sound pretty good ported
  14. #42
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    Thanks for bumping this year old thread that no one cares about
  15. Thanks av83 thanked for this post
  16. #43
    jungstah's Avatar
    jungstah is offline Senior VIP Member
    May 2012
    san francisco
    278
    78 Post(s)
    If you just want to have beat for cheap, get some hifonics hfi's or hfx watevers and throw 500-600w rms at em. you'll be plenty satisfied for a first setup.
    Pioneer AVH-P2400BT
    Stock Pioneer 4" components
    Hifonics Brutus BRZ1700.1D
    Two SA-12's
    cruddy prefab ported box----new box otw
  17. #44
    av83's Avatar
    av83 is offline CarAudio.com Veteran
    Mar 2012
    Illinois
    3,031
    13 Post(s)
    1335 Post(s)
    No. do your research. Kicker subs, imo, are overpriced at all of their levels. Not saying they suk. I'm saying that for the price of their entry level gear, you can get mid level gear from a company that spends less on advertising. Do homework. Compare voice coil sizes, rms power handling, etc. See what your $ is getting you...
    80prs
    SoundQubed 6.5 Pro's DD T2 Tweeters / new 4 Chan coming / new subs coming / DC Audio 5.0K
    Singer 310 6 phase 2 runs of Monster Cable 1/0 / Exide g78 AGM under hood and XS D3100 in rear
    Plenty of deadener. CCF and fiberglass insulation in doors... thanks to the advice of keep_hope_alive they sound AWESOME! :-)
  18. #45
    TitoThePirate's Avatar
    TitoThePirate is offline Newb Nuthugger
    Feb 2012
    Milwaukee,Wi
    26
    456
    161 Post(s)
    CVX is better, buy you can do better for the price.
Tags for this Thread
