+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 49
Reload Thread: Kicker CVR vs CVX
  1. #16
    Bass Addict's Avatar
    Bass Addict is offline customizer
    Dec 2008
    somewhere in the mountains
    1,341
    Re: Kicker CVR vs CVX
    Quote Originally Posted by elballz12 View Post
    So the 4 ohm subs would be the ones that would be needed to be wired at 1 ohm. How would the amp and sub be wired?
    if you buy new subs,there will be,or should be wiring instructions for the subs in the subs boxes.and yes,two dual 4ohm subs can be wired down to 1 ohm load to your amp
    Ride;370z
    alpine 9887
    DD6
  2. #17
    Dec 2008
    1,341
    what amp did you have powering it?
    kicker zx1000.1 the one in my sig.i have used this 1 amp to power a cvx,re sx,and now a diamond d6.i used the cvx for a few months and then sold it.still looked brand new
    Ride;370z
    alpine 9887
    DD6
  3. #18
    elballz12's Avatar
    elballz12 is offline Member
    Nov 2011
    Decatur, AL
    86
    yes i would be buying them new. Would the subs not be underpowered with that amp?
  4. #19
    Dec 2008
    1,341
    yea they would,i was only using 1 cvx 12 and i was beatin on it pretty good.never had a problem out of it.eventually though,you will want something that sounds better.
    Ride;370z
    alpine 9887
    DD6
  5. #20
    NissanKicker's Avatar
    NissanKicker is offline Honda-on-22-Nissan-on-20
    Oct 2007
    Ruston/Grambling, LA
    25
    1,420
    This was when I had my 2 12" CVXs in my Nissan Sentra - I built the box ( 5.51cuft tuned @ 37.5hz )
    ... The amp I was running was a Power Acoustik Stax 5500/1D ( WAY too much power for them, but I loved it EVERY BIT! )
    This is when I had my 2 12" CVRs in my Nissan Sentra - I also built the box ( 5.51cuft tuned @ 35hz ) - Same size box, different port tuning
    ... I had an Autotek AT-2000.1D on them at first, then I changed to the Power Acoustik 5500/1D...
    MY OPINIONS ON THE SUBS!
    ... The Kicker CVRs:
    They hit harder than your average, budget subwoofer... They just can't take the power for a long period of time at high volume. Overall sound and quality and effieciency - they pass the test! What I like about them the most - they hit BOTH ways ( In & Out ), alot of subs hit just 1 way.... Kicker made sure that this sub was capable of products every single note in it's range....
    ...The Kicker CVXs:
    They can take a TREMENDOUS amount of abuse... They handle the power they are rated at ( 750 ) VERY WELL, and the good thing is, you can add alittle more and still sound decent! They don't get very low, but they hit their notes with authority! If you can afford them ( they aren't expensive at all ) GET THEM!
    WORDS FROM THE EXPERIENCED & WISH:
    ... It's ALL in the enclosure that you have built for them... If your enclosure is right, you don't need all that power... ( But it never hurts to have TOO much power - Just tone it down. )
    Vehicle: 1999 Nissan Sentra GXE 4-Dr [ Lambo Doors ]
    Head Unit: Alpine CDA-124SXM
    Front Stage: Kicker DS6.5s w/ (4) Power Acoustik NB.4s - Rear Stage: (4) JVC 5-Way 6x9s
    Sub Stage: 18" FI Audio Q - Custom Ported Enclosure: 6.41 cuft Tuned @ 29Hz
    Sub Amp: (1) Kicker KX2500.1D - Highs Amp: AutoTek AT-1200.4
    Processors: Clarion EQ-746 & Clarion MCD-360
    Wiring: Install Bay 1/0 Gauge ( Including Big 3 Upgrade )
    Batteries: EverStart Maxx's ( 750 CCA ) In Front & Back
    DJ's Installation
  6. #21
    elballz12's Avatar
    Nov 2011
    Decatur, AL
    86
    so if i were to get 2 12" CVX would the Hifonics Brutus BRZ1700.1D be a good amp for them? and thanks for your opinion by the way
  7. #22
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,860
    72 Post(s)
    As was already stated in this thread much much better can be had then cheap as over priced kicker lol.. With that much power big 3 and a second batt will probably be needed so keep that in mind on a budget...
    Western Rep.
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
    -Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
    -Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
  8. #23
    Oct 2007
    25
    1,420
    You're welcome... And yes, the Hifonics Brutus 1700.1D will be enough power...
    DJ's Installation
  9. #24
    VisceralSound's Avatar
    VisceralSound is offline CarAudio.com Elite
    Oct 2011
    Rochester, MN
    1,606
    20 Post(s)
    Skip the kickers and hit up a Skar VVX or RE SXX
    References: BigSix,
    This industry is about innovation and setting your own path
  10. #25
    elballz12's Avatar
    Nov 2011
    Decatur, AL
    86
    How much would the big 3 and a battery run
  11. #26
    Oct 2007
    25
    1,420
    Cheap... Batteries aren't expensive... And the big 3 can be done by yourself... ( Youtube - Big 3 Installation )
    DJ's Installation
  12. #27
    elballz12's Avatar
    Nov 2011
    Decatur, AL
    86
    what about an optima yellow top? is that an good option?
  13. #28
    Dec 2010
    Grand Junction, CO
    16,860
    72 Post(s)
    Quote Originally Posted by vISUALHype View Post
    This!
    No look into Deka or XS power...
    Western Rep.
  14. #29
    elballz12's Avatar
    Nov 2011
    Decatur, AL
    86
    okay so which model?
  15. #30
    thedancer1987's Avatar
    thedancer1987 is offline Junior Member
    Jun 2012
    kelseyville ca
    well im running 2 15 cvr's and there duel voice coil at 4 ohm and i have them briged to 1 ohm stable on a hifonics brutis 1700.1 mono amp and it hit super hard im hitten at least a 142 db,s im ganna be getten a hifonics brutis 2100.1 soon so im hopen its ganna hit pritty hard. my buddy is runnen 1 12 cvx in a 1.8 cubic foot sloted box with a 650 kicker amp and hes hitten a 141.1 db so i agree the cvx's are much better and can handle a lot more but still put out a lot of bass and clarity with a low watt amp but my suggestion is deff ither one u pick ither the cvx or cvr the hifonics brutis is the way to go for sure it sund realy good
    but my persanl suggestion would be if ur ganna run the cvr's the 1700.1 brutis would be grait but if ur ganna go with the cvx's prob do the 2100.1 brutis or the 2400.1 brutis and ull be dumpen hard lol oh and if ur tryen to stay in ur buget check out ebay u will get realy good deals hope u enjoy and i hope any thing i said helps
+ Reply to Thread
Tags for this Thread
