when you buy it there's a diagram really simple, just sounds complicated.
---------- Post added at 10:09 PM ---------- Previous post was at 10:08 PM ----------
$5 runnings, walmart, autoparts store if even $5
yea, that's a thought, i'll look into that, thanks.
dave
1999 Buick Park Ave Ultra
Head Unit: JVC KWHDR720
EQ: Audiocontrol EQL
Front Stage: Hybrid Audio Technologies Imagine 5.25
Sub Stage: In process (will be Boston G310)
Amp: Boston Acoustics GTA-704 4 Ch
Rear Fill: Boston SE953 6X9's
Just run a wire out from your car's fuse panel. Find a fuse that's ignition switched, and run a wire from it (down stream side of fuse) to the rem turn on of your amplifier.
No speaker, in the history of speakers, has ever been blown by too little power. Ever. I don't care what your friend told you, he's a dirty liar.
Pay United Radio to fix your headunit.
CA.com FAQ's
CA.com TOS Agreement
Forum Rules
A Technology Related Blog
HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
Front Mids: Eclipse SC6500
Front Tweeters: Morel made Xtant 28MM Silks
Subs: Audiomobile Evo 10" TC2+
Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
Amp: Audio Systems Twister F6 380 III
yea, the red wire should have worked, i don't know what the deal is with the wiring in the back of the deck, i did a pretty shabby job installing everything years ago, i need to redo it. i don't wanna pay to have the deck looked at, if anything, i got a buddy who will sell me his old eclipse deck for $40. i've never heard of wiring anything straight to a fuse before, that's a thought. i think i'm gonna go fool around with it for a bit again before i take off for work here. thanks for the input fellas.
You can also run it to a toggle switch/pref one that lights up,so to remind you to turn off,and wire to AUX in the fuse panel,or Extra???You can even wire it to radio fuse under dash,so that it will work off ignition(toggle power) .Just have to remember to turn volume down,and switch it off...you know??Done a by-pass for a fan-relay on a honda like this.Or??Try repairing /replacing radio ?????
Bookmarks
