Results 1 to 8 of 8
Reload Thread: need advise on wiring my subs
    crzybob77's Avatar
    crzybob77 is offline Member
    Mar 2002
    Richmond, VA
    33
    88
    Icon33 need advise on wiring my subs
    Alright, i am going to be getting two 12" single 4ohm voic coil subs. I want to wire them as a 2 ohm load on my amp to get the most out of my class D mono amp. I know that they need to be wired in parallel to do this. I talked to some people at crutchfield about the wiring diagram that they have one their site :
    http://www.crutchfield.com/infocente...fiers_faq.html
    It is near the bottom of the page.
    I want my amp to be 1 channel (bridged). So, they said to put 2 wires into the positve and 2 wires into the negative terminal on the amp and then take those 4 wires and hook them to alll the positive and negatives on the sub. They said this will make a bridged 2 ohm load. Does this sound correct?
    Check out my system at http://www.sounddomain.com/id/crzybob77
    crzybob77's Avatar
    Mar 2002
    Richmond, VA
    33
    88
    Icon32
    one more thing..... my amp is a US acoustic class D mono sub amp. It is 600 x 1 at 2 ohms. So, the 2 subs will get 300 watts a piece when wired in parallel like i explained before, right?
    mykeys's Avatar
    mykeys is offline URABUS
    Nov 2001
    South Prairie, Wa.
    45
    1,057
    Yeah that sounds right...Also it sounds like they built the amp like JBL with two speaker terminals.. The terminals both pos and both neg are connected internally so you can hook them up to one set or both and not have any worries.. just an FYI
    Mike
    Your friendly neighborhood subaru freak!
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    are your subs svc or dvc??? cause that might change the wiring scheme slightly....good luck
    crzybob77's Avatar
    Mar 2002
    Richmond, VA
    33
    88
    Icon31
    Single Voice Coil (4 ohm)
    imral3's Avatar
    imral3 is offline Sponge Bob Rules !!!!!
    Jan 2002
    NJ
    50
    526
    just wire subs like the website instructed and you will be getting 300w to each.
    p.s., i also added a comment to your web page.
    good luck and good listening!
    L8r
    infinity311's Avatar
    infinity311 is offline Junior Member
    Apr 2002
    i forgot
    i hear this guy, crzybob77, eats ****, like mad.
    Future System Specs:
    Deck: Pioneer DEH-4400
    Speakers(front): Infinity
    Reference 5.25 (rear) Infinity
    Kappa Perfect 5.25
    Rockford Power 400.4 amp
    2 MTX 6000's 12 inches
    Rockford Power bD500.1
    Rockford 1 farad cap
    Apr 2002
    i forgot
    you also spelled "advice" wrong (*******)
    Kappa Perfect 5.25
