Results 1 to 6 of 6
Reload Thread: kicker 06zx1500.1 tunning with a jl 13.5w7
    assassin1840's Avatar
    assassin1840 is offline CarAudio.com Elite
    Aug 2011
    mi
    1,212
    2 Post(s)
    so im trying to figure out where the settings should be on this sucker i swear its not sounding right i had gain it half way with the crossover set to about 80 and the bass boost on 0 and it was loud and clean but i just got my new fuse today before i had a little dinky 60 amp fuse but now i have 150 fuse on it so i turned it to 3/4th gain up and everything esle the same its loud but doesnt sound to much louder or could it just be due to my small car civic ex i can sell this sucker in two days should i get the jl slash 1000.1 v2 or would this due with some fine tuning but theres barly any options on this amp oh my sub is 3 ohms but i still should get over 1k rms how do i know how to set it to get a clean 1k any input would help
    vaiboy's Avatar
    vaiboy is offline Senior VIP Member
    Sep 2006
    Phoenix, AZ
    241
    1 Post(s)
    Re: kicker 06zx1500.1 tunning with a jl 13.5w7
    You should use a DMM to set your gain, the gain is technically not a volume knob. The output should be at 54.7VAC for 1000W@3Ω.
    http://mobile.jlaudio.com/pdfs/gainSetting.pdf
    destined2race's Avatar
    destined2race is online now Already Being Used....
    Jun 2008
    Beatin Down Yo BLock
    913
    1 Post(s)
    first i would use some sentence structure holy moly! j/k but ya set w/ a DMM and the 1000/1 would be a great match for this, but the amp you have should have plenty of power. I guess on the sq side im not sure how it would compare to the JL amp. I know the JL amps have great sound control and JL supplies an exact settings chart for the W7s. I got the 500/1 on my 12w7 and sounds awesome. I just looked up the chart and JL had the recommended settings for mine in the HO box even.
    Headunit - Kenwood DDX 318 4v double din
    Front Stage - JL Audio c2 6.5 comp set
    Rear Stage - Jl Audio VR 6" comp set
    Front stage amp - OS Sony (.005 THD Rated)
    Sub Stage - 2 10" IDs 1cu sealed per
    Sub Stage Amp - Boston Acoustic GT-28
    Big 3, SVR800 Batt, JL Blue Line Rca's, 0 ga JL kit
    Refs - The_Grimy_One, Deusle, zach90z, shineman08, Orion 2500D
    Aug 2011
    mi
    1,212
    2 Post(s)
    yeah my vocab ***** donkey di ck but oh well. so it really doesnt matter how much i turn my gain on really? i hook up a dmm to the pos and negitive and it should read about that on my high out put on my hu
    vaiboy's Avatar
    Sep 2006
    Phoenix, AZ
    241
    1 Post(s)
    Quote Originally Posted by assassin1840 View Post
    You would have to double the power to gain 3db in output, if the voice coil in the sub can handle the added power. So lets assume by cranking the gain up to 3/4s the amp is able to produce a maximum 1150W@3Ω. It's only going to get you a few tenths of a decibel more than 1000W, it would be hardly noticeable, but you would likely be clipping the output which can damage the subwoofer and the amp. It's not really what you want to do.
    Follow the instruction in the PDF and measure the AC voltage at the amplifiers subwoofer/speaker output. 54.7VAC is the voltage that amp is rated for, it would be the same voltage for 750W@4Ω and 1500W@2Ω. Save your equipment.
    Aug 2011
    mi
    1,212
    2 Post(s)
    thanks will do but i just sold the amp a few mins ago lol paid 115 last week just sold for 300 now gotta get a new amp maybe sell the jl maybe go a whole new route that bass was just way to much and over kill for my car. i guess i gotta think if i am going to keep my car or get a suv
