Results 1 to 7 of 7
Reload Thread: help??
    Aug 2011
    Hodgenville, KY
    214
    17 Post(s)
    help??
    will a 220amp alternator be enough power to hold 13 to 14v with 4 extra c&d batts and while running about 6000 to 7000rms? for my s10 blazer
    aaronwhitlock3's Avatar
    aaronwhitlock3 is offline Banned
    Aug 2011
    Hodgenville, KY
    214
    17 Post(s)
    Re: help??
    anyone?
    subzero's Avatar
    subzero is offline CarAudio.com Veteran
    Sep 2008
    Phoenix, AZ
    41
    6,793
    30
    7 Post(s)
    456 Post(s)
    Re: help??
    dude, Contact Nate at Excessive Amperage. Alternators can charge to whatever you need. Example: I have an adjustable voltage ragulator. I can charge from 13V up to 20V. I have mine set at 15.2V. and charging begins at 1000rpm. for my setup. Reaches max at 3K I think. and it does 285amps Max at max. so. Yes you can do if you got the $ and the need...
    The best way to sustain that kind of power your looking at running is batteries.... Get yourself a battery bank
    2016 Chevy Cruze LT
    Pioneer DD 2700BS , JBL MS8 all active , ARC XDI805 channel, FOCAL-100KRS set - active- Dayton Audio SD215A-88 8" DVC Subwoofer as Midbass - sub- one Crescendo Forte 12., (1) Alpine-MRD-M1000
    Aug 2011
    Hodgenville, KY
    214
    17 Post(s)
    Re: help??
    ok well how do iu contact this person and about how much would it cost?
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,942
    109 Post(s)
    7667 Post(s)
    Re: help??
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
    OldSchoolRF's Avatar
    OldSchoolRF is offline Senior VIP Member
    Jul 2011
    Kentuckiana
    346
    45 Post(s)
    Re: help??
    Yes that's plenty
    I'm always looking for older Rockford Fosgate equipment. Anything from 2004 and back. Send me a PM if you have something for sale.
    Currently looking for:
    1501bd & 1500bd
    Power HX2 & Team RF Motors, Baskets, Dustcaps, ect.
    Oval Bass Knobs
    References - CACO: BassAddictJ, Reeftopia, Skartisu, Tuck05, Snow713, Shakindablock, PSI, Shocker, beatnbronco - CA: aaronwhitlock3, 07sciontc - DIYMA: GroundScr8pr
    mast240's Avatar
    mast240 is offline YOU'RE A HOOKER!
    Mar 2011
    washington, dc
    3,326
    87 Post(s)
    Re: help??
    the biggest thing you want to consider, when talking about alts and batts... is what type of batteries your going to be using (rated AH), versus the amps output... if you add too many large batteries to a single alt, you can burn the alt up...
    another REALLY big thing to consider, is when the alt reaches max output... some of the lower quality alt companies out there, use changes in pulley size, to aquire higher output... but that, can mean it wont hit this output until a higher rpm.... meaning, if your parked, and at full tilt, you'll either have to rev really high, or suffer some voltage drop... just food for thought
    NEW TO CAR AUDIO? READ THIS FIRST... http://www.caraudio.com/forums/general-discussion/532425-new-car-audio-read-first.html
    the loudest montero sport around
    head unit: toshiba thrive 10.1" android tablet/ Kenwood KVT-516
    front stage: each door: 1 8' RF p1 (midbass), midrange: 2 cadence cwm6.5's, 1 memphis pr 6.5 coax (kickplate), 1 cadence 4' coax (a-pillars)
    subs: 4 AQ HDC3 18'S, walled in a clamshell
    amps: subs: AB 500.1, looking for a second; midrange and midbass: 2 AP 1000.4
Tags for this Thread
