Re: Would my amp work with these subs?
I bought two of the newer type r 10's for $140 used off ebay and an audiopipe 1500d for $115 local. The 12's shouldn't be too much more used on ebay. You can get the same amp new for ~$140 from vmi with a code. With this setup your looking at around $320-$340, but you will still need wiring and a box. Its a little over your budget of $250, but just recommending the route I went with my budget build. Hope this helps.
Headunit: Clarion nz500
Front Stage: Kicker 6X8 (2) Kicker 5 1/4 (2)
Rear Stage: Kicker 5 1/4 (2)
Mid Amp: Hifonics Titan TXi 4408
Sub Amp: Audiopipe 1500d
Subs:Alpine Type R 10'' (2)
Box: TBH 4th Order @ 45hz
Wire: 1 run of 1/0awg Big 3 1/0awg
Alt: Stock 130 amp
Bookmarks
