Results 1 to 10 of 10
Reload Thread: is a 170amp ho alt good enough for AQ3500D.1?
    myjaja's Avatar
    myjaja is offline Audioque
    Sep 2006
    San Antonio, Tx Posts: 143,632 _____<^>*_*<^>_____
    3,655
    492 Post(s)
    I have a 96 honda accord with a 90 amp stock alternator. I know for sure I need a ho alt for that AQ3500D amp. But will a dc 170 amp ho alternator be enough? thanks
    Refs: sbcaprice305, mattmcss, systembumping, LeofromtheH, audiobahnuser18, stishdr, wcarson8911, jnoel, mr_kebo, 93 saturn sl2
    HU: Home stereo converted to dc
    Speakers: Stock
    Subs: 6 1/2 home sub
    Amp: off the stereo
    Wiring: extended power cord
    neon lights: Christmas lights duct taped to frame
    mast240's Avatar
    mast240 is offline YOU'RE A HOOKER!
    Mar 2011
    washington, dc
    3,326
    87 Post(s)
    Re: is a 170amp ho alt good enough for AQ3500D.1?
    you'll def be pushing the limit on that... how many and type of batts will you be running, and what final load will the AQ see?
    NEW TO CAR AUDIO? READ THIS FIRST... http://www.caraudio.com/forums/general-discussion/532425-new-car-audio-read-first.html
    the loudest montero sport around
    head unit: toshiba thrive 10.1" android tablet/ Kenwood KVT-516
    front stage: each door: 1 8' RF p1 (midbass), midrange: 2 cadence cwm6.5's, 1 memphis pr 6.5 coax (kickplate), 1 cadence 4' coax (a-pillars)
    subs: 4 AQ HDC3 18'S, walled in a clamshell
    amps: subs: AB 500.1, looking for a second; midrange and midbass: 2 AP 1000.4
    martin8's Avatar
    martin8 is offline Senior VIP Member
    Jun 2011
    quartzhill
    258
    seems small i have a 150 fuse and im runnin 1200 watts
    mast240's Avatar
    Mar 2011
    washington, dc
    3,326
    87 Post(s)
    its not always ALL about the alt... for cars like hondas, which have very small alts to begin with... you can substitute a lil bit with extra batt power... but that only goes so far
    myjaja's Avatar
    Sep 2006
    3,655
    492 Post(s)
    Quote Originally Posted by mast240 View Post
    I have a huge red stinger battery in the front(forgot the model on it) and a smaller stinger battery in the back. I really dont know the models on them. I plan on putting kinetic though in the future. Ill also be running it at 1 ohm. That ho alt runs at 110 amps at idle btw.
    Speakers: Stock
    Amp: off the stereo
    mast240's Avatar
    Mar 2011
    washington, dc
    3,326
    87 Post(s)
    Quote Originally Posted by myjaja View Post
    eek... i would say, if its just going to be for burps.. you could make it work... but as a daily, with those batts, and that impendance load, that amp will be seeing below 12v quite often
    myjaja's Avatar
    Sep 2006
    3,655
    492 Post(s)
    What would be a good alternator size to keep the voltage up with that amp? I noticed high output alternators for honda accords tend to be pricey. I checked ebay and its all junk. DC is the only good one ive found, but the price is a little too high.
    Speakers: Stock
    Amp: off the stereo
    mast240's Avatar
    Mar 2011
    washington, dc
    3,326
    87 Post(s)
    the problem with hondas, in general, is the casing size on the alt... its just really hard to fit enough into that small of a casing size to put out more then 170... but for that, on a daily setup, i would say at a MINIMUM, 220 with atleast 2 good helper batts... wish i could help you with a good link for that size on a honda, but i have yet to see any quuality ones
    i know that mechman will build a custom alt for you, but that can be pretty pricey... but if you can afford it, it'll def be worth it
    DC also has great quality, and will build custom... but their custom builds can take FOREVER, and are also somewhat pricey
    you might also want to contact ohio generators, as they might be able to help you out
  9. #9
    KyleBechtold's Avatar
    KyleBechtold is offline Buy my fuses $1.25ea
    Nov 2008
    Tampa, Florida
    7,218
    126 Post(s)
    I have a 96 honda accord with a 90 amp stalk alternator. I know for sure I need a ho alt for that AQ3500D amp. But will a dc 170 amp ho alternator be enough? thanks
    really that was what sounded best in your head.. hmm ok..
    like the saying goes you gotta pay to play.. can you run it sure.. would I.. NO.. I wouldn't use a redtop period.. for any draw..
    Ca.com
    Bought from: Sctattooer, Korn4Life, wgsj_fortvalley, bk12321, Queball, bumpincrv, Splmaster, 310w6, Buck, liljojo4711
    Everyone I have Bought from has been awesome.. feel safe with any of them..
    Sold To: Iakona, dustinr, squeak12, Worstenemy453, BeAlLsTaR13, rmzsuzuki89, c_b_, mendon mafia, dropped_tb, SPLluminator, violence., power-fanatic07, schackel, michaellane, aviator08, kodak314, dropped_tb
    Ref Link
    Tamparacing
    -b15spec, 727kid, pshull727, Nt_Hardcore
    Want/Need ANL fuses cheap 150a 200a 250a 300a
    CLICK ME
  10. #10
    myjaja's Avatar
    Sep 2006
    3,655
    492 Post(s)
    Oh, I called them. My friend has a shop and told them about the amp and about my car. They said they can get me an ho alt that does around 180-193 amps for $395 as long as we show them the tax id of the shop.
    thanks for all your help though
    Speakers: Stock
    Amp: off the stereo
