Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: 07 scion tc help with system wires
    07sciontc's Avatar
    07sciontc is offline memphis and sundown
    Jan 2011
    Hotsprings,va
    146
    im doing a full system in my scion tc dyno mat and ill have a nav tough screen with a 4 chanul amp running about 75 to 100 watts per chanel and a mono block at about 3000 rms give or take 500 im planning on doing the big three and running all 0 gauge for big 3 and amps i need to know should i upgrade my alt and should i add some xtra bats like one big one or maby 1 smaller one 2 smaller please help me lol thanks
    >>SQL<<'s Avatar
    >>SQL<< is offline CarAudio.com Elite
    May 2011
    USA
    1,461
    1 Post(s)
    Re: 07 scion tc help with system wires
    Try using the "ENTER" key every now and then.
    Makes it much easier to read your post.
    3,400 watts will need apx 280 amps
    You should look for a 300 amp alternator.
    Someone else will need to chime in about the batteries as I have no experience using them.
    07sciontc's Avatar
    Jan 2011
    Hotsprings,va
    146
    sorry for the hard reading and thanks for the info the biggest alt i found for my car is 270a from mechman its a case upgrade
    pro-rabbit's Avatar
    pro-rabbit is online now Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,070
    348 Post(s)
    270 would get the job done with the added batteries.
    As for the sub stage and amps...that all depends on your budget..also make sure budget wire/enclosure(or materials if you build it yourself).
    As for sound deadening, I would look into Audio Technix which is a vendor on the forum.. CLICK HERE >>>>>>>> Audio Technix
    DDtC's Avatar
    DDtC is online now Go cheap you get cheap
    Apr 2011
    Va Beach, Va
    32
    5,954
    44 Post(s)
    I run 2800 at .5 with my tC, off a 200 amp HO and 2 yellow tops. I dont drop below 12.
    • 2010 Scion tC
    • Alpine CDA-117
    • JL 450/4v2 Active (Mid range, tweeters) JL 300/2v2 (Mid bass) DC 5K(Subs)
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
    • Singer 300 amp 15.1v bypass, 3 XS D3400s
    • DD M4a and XS D3100 coming soon
    • Viper 5701 with Smart Start
    07sciontc's Avatar
    Jan 2011
    Hotsprings,va
    146
    thanks for the info and i dont have a buget cuz as long as i get a good deal ill get all the stuff and then do the install and ill look into the mat thanks dose anyone know a good box builder on hear
    DDtC's Avatar
    Apr 2011
    Va Beach, Va
    32
    5,954
    44 Post(s)
    Excessive amperage.. 200 amp for $410 shipped. If your running 1ohm or higher its all you need.
    • 2010 Scion tC
    • Alpine CDA-117
    • Hertz HV 165XL
    • Hertz HT28
    • JL ZR800
    • 2 x DD 9512i
    07sciontc's Avatar
    Jan 2011
    Hotsprings,va
    146
    but im also using another amp for my other speckers wouldent i need a lil bit more and i might go more watts if the amp can hold it that why im sticking to 3000 or so watts cuz i wasent sure lol i relly wana runn 4 orion 10s or 2 or 4 12s that would be 6000 rms
  9. #9
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,070
    348 Post(s)
    You don't have room in the stock cargo area for the much...limited to 3 10s or 2 12s in most cases...I could be wrong though.
    A 200amp alt with a decent battery setup will be fine.
  10. #10
    KyleBechtold's Avatar
    KyleBechtold is offline Buy my fuses $1.25ea
    Nov 2008
    Tampa, Florida
    7,233
    1 Post(s)
    I have sat in them and those back seats are smaller than a child seat you might aswell take em out and go balls to the wall
    Ca.com
    Bought from: Sctattooer, Korn4Life, wgsj_fortvalley, bk12321, Queball, bumpincrv, Splmaster, 310w6, Buck, liljojo4711
    Everyone I have Bought from has been awesome.. feel safe with any of them..
    Sold To: Iakona, dustinr, squeak12, Worstenemy453, BeAlLsTaR13, rmzsuzuki89, c_b_, mendon mafia, dropped_tb, SPLluminator, violence., power-fanatic07, schackel, michaellane, aviator08, kodak314, dropped_tb
    Ref Link
    Tamparacing
    -b15spec, 727kid, pshull727, Nt_Hardcore
    Want/Need ANL fuses cheap 150a 200a 250a 300a
    CLICK ME
  11. #11
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,070
    348 Post(s)
    Quote Originally Posted by KyleBechtold View Post
    This
  12. #12
    07sciontc's Avatar
    Jan 2011
    Hotsprings,va
    146
    i have a kid and haul him in it and im takeing out the floor in the back for more room
    ---------- Post added at 01:24 PM ---------- Previous post was at 01:23 PM ----------
    but i will get everything set up i might go with a diffrent woofer that takes more power
  13. #13
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,027
    28
    124 Post(s)
    why don't you spend the money on your kid? just keep the subs off while he's in it. permanent hearing damage is easier with younger ears.
    /serious comment
    i agree a 200A alt will help a lot and probably be sufficient. you won't be drawing 3kW all of the time, most of the time you'll draw much less. it really depends on the amp you get and what you listen to. extra batteries in hatchbacks are a hassle given the need to secure and vent them. make sure everything is well secured, you don't want projectiles.
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
  14. #14
    07sciontc's Avatar
    Jan 2011
    Hotsprings,va
    146
    hes got plenty trust me and hes not always in the car and iv got 5 cars and this is one with the lowest miles and stuff so thats why im doing it to this one all my others dont have nuthing but my dodge ram is getting one also just want the tc done first
  15. #15
    May 2007
    Quad Cities, IL
    5,027
    28
    124 Post(s)
    cool. we get all types, i have to cover the bases.
    H.O. alt and a battery or two (depending on size) should have you covered. 1/0 wiring for all, i'd even consider running a 1/0 ground or two to the front given how cheap the steel is on the Scion.
Tags for this Thread
