Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Reload Thread: Battery Gurus, Help Please!
  1. #16
    sacsking916's Avatar
    sacsking916 is offline stayin high an loud
    Apr 2009
    emerald triangle..home of da trees
    6,428
    323 Post(s)
    Re: Battery Gurus, Help Please!
    then your kinda screwed. run less power than.
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
    Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
    Apparently I was called out, or called a goat fucker, or something. I really have no idea. Im just along for the ride at this point.
    Quote Originally Posted by CRXBMPN View Post
    King James has nothing on King Sac!
  2. #17
    Bassin Brandon's Avatar
    Bassin Brandon is offline Banned
    Jun 2011
    Bay Area, CA
    950
    Quote Originally Posted by Joseph7195 View Post
    Hey Brandon, I looked around and this was the only thing I could find that might help. I am not familiar with the space available in your engine bay, but I thought it might be worth you taking a look. Hope this helps!
    Rugged Ridge DUAL BATTERY TRAY KITS FOR JEEP CJ WRANGLER - JCWhitney
    thank you for the help joseph, I have seen these, the only problem is it will only hold optimas...and I doubt 2 redtops can power this system and my car =\, correct me if I am wrong there please.
  3. #18
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,902
    3 Post(s)
    1624 Post(s)
    FYI Redtops are not the same as yellow tops which are deepcycles. In other words, if a battery is not a deepcycle, it shouldn't be depleted rapidly. Hence why redtops make good starting batts and yellow tops are good for running off your amps.
    OP if you know anyone who is good with welding you can have them make you a custom battery rack which will hang underneath your vehicle.
  4. Thanks Bassin Brandon thanked for this post
  5. #19
    dbeez's Avatar
    dbeez is offline CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    9,436
    1 Post(s)
    915 Post(s)
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps 2 Sax125.2 front stage crossfire [email protected]
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters 2 sets cdt m6+ mids 2 sets cdt tw25 tweets
    Subs 2-18" nightshade v2's d2
    System DetailsDaily driver.
  6. #20
    Jun 2011
    Bay Area, CA
    950
    I just can't wait until I can get this finished and finally enjoy bass again . It has been too long without bass D:
  7. #21
    Joseph7195's Avatar
    Joseph7195 is online now Walkin Tall
    May 2011
    Saltillo, Mississippi, United States
    38
    1,467
    385 Post(s)
    I went back and looked, and I found this little it of info (Hidden in a jumble of tiny fine print lol)
    "CJ & Wrangler kits place the battery side-by-side and may be used with lead acid or cylindrical-style sealed gel cell batteries."
    So I think if it's for the CJ You can use both cylindrical and box lead acid batteries, but if it's for the TJ, it says this=
    "TJ Wrangler kits stack the batteries and are for use with cylindrical-style sealed gel cell batteries ONLY due to the battery mounting."
    So I am thinking it might just be the style you order. I still honestly don't know if it could fit your application. If it does work, You might be able to use a regular battery and a high amp battery, just as long as it has about the same dimensions as a regular battery.
    I would hate for this to not work for you, but if it didn't, I am almost positive they would let you return it without problems!
    Quote Originally Posted by adulbrich View Post
    We don't have food stamps on the east side. Its called a link card. Man, the grocery is packed on the first of da month. I shit you not, a homie got stabbed over a can of soup.
  8. #22
    Apr 2009
    6,428
    323 Post(s)
    what are you going to be running that will need that much power?
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
  9. #23
    Jun 2011
    Bay Area, CA
    950
    I have a TJ and have already investigated this idea...it seems to be a dead end...however I will call the manufacturers and ask them again haha.
    I have 2 custom made 10's that will be powered by my Crescendo BC3500....... each sub will be getting roughly 2350 watts.... so thats a total of 4700 watts for both subs....
