Results 1 to 5 of 5
Reload Thread: Help wiring MTX Re-Q5
    fuze's Avatar
    fuze is offline Junior Member
    Nov 2010
    Michigan
    Hey all,
    I am trying to add a 10" Alpine Type R subwoofer and a mono amp to my stock 4 speaker car audio system in my 08 Charger. (There are only 4 speakers in my car, 2 in front 2 in back.)
    Here is what I purchased(many months ago, just now trying to install it)
    10" Alpine Type R
    Boss Audio Onyx NX1800.1 amp
    MTX RE-Q5
    I used an amp wiring kit to hook everything up, and it looks like the power and remote side of things are fine. Both the amp and the RE-Q turn on when my key is turned in the ignition and both have the power lights on.
    Im stuck on how to wire this RE-Q to get the signal for my new subwoofer.... I tapped into my rear speaker and connected it to the RE-Q wiring harness but nothing is happening.
    I feel really dumb right now.... thought this was going to be as easy as tapping into a speaker wire but apparently im missing something.
    any help would be great lol
    fasfocus00's Avatar
    fasfocus00 is offline doITdaWHITEwayORdoITtwice
    Jun 2007
    New Orleans, LA
    5,618
    3 Post(s)
    459 Post(s)
    Re: Help wiring MTX Re-Q5
    should have went with Audiocontrol.
    Here is my feedback Thread: http://www.caraudio.com/forum/showth...ght=fasfocus00
    "If you ain't cheatin', You ain't trying"
    winkychevelle's Avatar
    winkychevelle is offline CarAudio.com Veteran
    Jun 2009
    Ponchatoula, La
    26
    3,418
    767 Post(s)
    make sure you tap at least two speakers so it can sum a stereo load. i have one and it works like a charm in my cruze also check you gain settings on the req5 since it is also a line booster you can have them set to zero and get zero sound. i just set them half way and adjusted my amp gain to match the req
    2014 Chevrolet Cruze Diesel
    2013 Chevrolet Silverado 3500HD 4x4
    need sub ideas 1.1 cubes tuned to 36hz 10s please
    fuze's Avatar
    Nov 2010
    Michigan
    ok, so i should tap into both rear speakers instead of just one?
    Ill try that and report back
    fuze's Avatar
    Nov 2010
    Michigan
    Quote Originally Posted by winkychevelle View Post
    hey man, i went back and tapped into both right and left rear speaker and nothing changed.
    But then I connected one of my speakers to the White/Red and White wires on the RE-Q harness and finally I got audio through my sub. The White/Red wire is labeled "Front Left" but does it matter if I use that one tapped into a rear speaker?
