Results 1 to 2 of 2
Reload Thread: amplifier help, new to car audio.
    tomistehbomb616's Avatar
    tomistehbomb616 is offline Junior Member
    May 2011
    pickerington
    i just recently purchased two Audiobahn Alum10n's which run at 800w rms, and i need to find an amplifier which will power those, and my door speakers, which run at 45w rms each. id like to find one decently cheap, as im just now graduating high school. help?
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Re: amplifier help, new to car audio.
    you won't get one cheap amp to run both speakers and subs at the power levels you want.
    get two separate amps, maybe even used. check the classifieds. a 2 channel amp for the speakers should be pretty cheap. a monoblock class D for the subs will cost a bit more. you need to determine the voice coil impedance for the subs. single or dual? 2 or 4 ohm? Powerbass has some affordable amps that are decent. what vehicle is this going into? some cars require adapters and interfaces to add equipment. do you have a factory or aftermarket head unit?
    don't forget an amplifier wiring kit, and paying someone who knows what they are doing to install everything.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
Tags for this Thread
